VideoHelp.com Forum
    Trendsetters
    Using ProShow Producer I have created a HD SlideShow video file. The Attributes are as follows
    HD 1080p 16x9
    1920x1080
    fps 59.94
    Progressive
    Extension is .mpg
    My questions are:
    1) What software to use to create a HD DVD from the mpg file?
    2) Can the HD DVD be created on a normal 4.7gb blank DVD ?
    3) What player do I need to play the DVD? (Eg BlueRay or a player that will upscale to 1080 and if so, which one)?
    4) I assume the TV would be capable of HD with a HDMI input ??
    Thanks for input and ideas.
    Zen
    1. http://www.videohelp.com/tools/secti...ring-bd-hd-dvd
    2. Yes but it might not work on all hd-dvd players.
    3. Only hd dvd players.
  3. Member racer-x's Avatar
    You can also play that file through a good set top media player like my Tvix SH4100. 60 fps for a slideshow is a waist, I would go with 23.97. If you encode it to VC-1 or H.264 and burn it to a data dvd, it might play back on an Xbox 360 or PS3.
    There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
    OK thanks for the tips. Going on similar advice, I just purchased a Laser MediaMate, which is similar to what you are suggesting
    (I think). I've put a 720 gb Sata drive inside it, and now have to sit on my hands while I read the manual. Link http://laserco.com.au/downloads/manu...usermanual.pdf
    So I hope this will display jpegs in a HD SlideShow format. Let me know what you think.
    Regards
    Zen
  1. proshow producer final video file
    By hamohd70 in forum Newbie / General discussions
    Last Post: 28th Dec 2008, 03:20
  2. Creating AVCHD from ProShow Producer?
    By h2oskierc in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Dec 2008, 11:53
  3. Create a Blu-ray Slideshow with ProShow Gold 3.5
    By photodex in forum User guides
    Last Post: 27th Oct 2008, 13:32
  4. Proshow Producer 3.2
    By nace in forum Authoring (VCD/SVCD)
    Last Post: 13th Aug 2008, 01:29
  5. slide show video with proshow producer to avchd on blu ray disk
    By LEONESVIZZERO in forum Authoring (Blu-ray)
    Last Post: 21st Apr 2008, 03:39
