VideoHelp.com Forum
Thread: Making a DVD
  1. I was recently in a play and we filmed it. I now want to make a DVD (with full menus) of the play that includes subtitles and an audio commentary track. However I have no idea where to start. Can someone point out a few tutorials for me to help me with this endeavor? Thanks
  2. Member ZippyP.'s Avatar
    What did you use to film your play? DV camera, DVD camera, VHS, hi-8?
  3. DV. I know how to transfer the video to my HD. What I need help with is the DVD creation and "special features" I also want to add a "photo gallery" to it, where the viewer can scroll thru pics, taken during the run of the show.
    You need an authoring tool, and to spend some time learning how to use it. They range from the simple, to the complex, depending on your needs. Yours are more than most simple tools provide, however you are probably not experienced enough for the tools that will.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Once you have movie on your drive, you may have to edit and create Mpeg2 DVD compliant file.
    After that you can use DVD authoring software to produce DVD and burn.
    Some simple software will let you do simple cuts conversion, production of menus and burn, but since you need subtitles, second audio track, pictures, none of those will do.
    Only one I know for what you want and for reasonable price is DVD Lab Pro.
    For that you will have to import DVD compliant file using TMPGEnc Xpress or other apps.
    To make audio commentary track, you can record it as you play the movie and than import to authoring software as second track.
    I do not know there is a simple tutorial to cover all this, you just have to learn
  6. Member t0nee1's Avatar
    You can create a simple home DVD with WMM,which comes with windows....
    And here is a guide using Nero Vision,not the best I know but will work..
    http://www.digital-digest.com/articl...ide_page1.html
    And see this list,
    http://wiki.digital-digest.com/index..._Tools_Roundup
    Good luck!...
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  1. Making a LP DVD
    By zarnic in forum Authoring (DVD)
    Last Post: 11th May 2011, 07:47
  2. making DVD
    By narcissus in forum Authoring (DVD)
    Last Post: 19th Jul 2008, 00:18
  3. making DVD
    By narcissus in forum Authoring (VCD/SVCD)
    Last Post: 14th Jul 2008, 19:22
  4. Need advice on making dvd copies and making ISO files please.Thanks!
    By Canon GL-2 Guy in forum Newbie / General discussions
    Last Post: 17th Jan 2008, 12:03
  5. making dvd;s
    By brenjim in forum Capturing
    Last Post: 14th Jul 2007, 11:48
