I couldn'f find anything posted about this problem, so here it is: on some of the DVDs I create with GUI for dvdauthor, the movie would start silent: no sound! If I hit Fast Forward, and immediately go back to Play, the audio starts playing normally. This happens only on my RCA player, but not on other players. On these DVDs, typically, this happens on chapter 1, at the beginning of the movie, and sometimes on another chapter. If it is chapter 3, for example, I would have no sound if I jump to chapter 3 from the menu, but the audio would keep playing if I just play the movie normally (or if I hit Fast Forward).
Not a major problem when you know the "workaround": hit fast forward, but a major frustration for anyone in the family who doesn't know the solution.
Typically, these DVDs are created from captured files from my RCA PVR, edited and cleaned up with Project X, and authored with GFD. It doesn't matter if I run PGCEdit, FixVTS. I suspect there might be something that can be set somewhere in GFD or after running GFD, because it is related to the chapters created by GFD, but I can't figure out what it is.
Many RCA DVD players have a feature called TV Guardian which is a foul language filter. It monitors the closed caption content of the video.
Maybe the filter is being triggered by a glitch in the file?
The file can be turned off in the DVD menu. -
Thanks for the suggestion. I don't believe I have this feature on my player. It's actually a PVR: RDS7000N (or DTH7000 in PAL version I believe).
I suspect I changed some configuration settings somewhere in the chain, as I seem to observe this more often recently. I am looking if I see anything, but it's tricky.
MeGUI, problem to encode audio from all AAC format(tape fast-forward sound)
By squall0833 in forum AudioReplies: 9Last Post: 13th Jun 2010, 14:54 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
audio video playing to fast
By John in forum ComputerReplies: 0Last Post: 16th Jul 2007, 13:40 -
I reformatted, Now Audio/Video is playing TOO FAST
By Xenogear900 in forum ComputerReplies: 5Last Post: 28th Jun 2007, 12:57 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
