Im curious to how the sensor captures footage. I have a PAL MiniDV camcorder which I know captures 25fps interlaced over 50hz. Because its interlaced, is it capturing 50 seperate fields per second (making it technically 50fps) or are the fields that make up a frame the same image, just odd and even rows?
Does the sensor capture the image progressivly and the processor converts it to the correct format?
It would actually be great if someone knows where to find some detailed explanations of how this works.
But 1/50th of a second apart, hence the interlacing lines you see on a progressive display like a PC.the same image, just odd and even rows
Most older cameras capture 50 fields per second. Some newer DV cameras can do progressive, as do most HD cameras.
Some starter reading : http://en.wikipedia.org/wiki/DV
Thanks for that, Ive been to Wiki and How Stuff Works and they dont explain the capturing side of things.
Most consumer camcorders (the one in my price range) are only able to capture an interlaced image. So they do capture 50 seperate fields then? Sorry Im a bit confused by your explanation.
Yes, 50 separate fields per second
Put another way. Every 1/50th of a second, the camcorder captures a half frame, or field. So every 1/25th of a second you have 2 fields making up a whole frame, but the two fields come from two separate moments in time, one containing the odd scanlines, the other containing the even ones. This is why interlacing is obvious when viewing the whole frame in motion scenes where there is drastic change between one field and the other. Because the two fields come from different moments in time it is important to maintain the field order throughout processing and also why deinterlacing results in degraded detail.
Buy My Books
HD camcorders w/ AVI format under 300$
By toddkreuz in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 5th Apr 2012, 16:26 -
Explain the format for newer HD camcorders
By jbitakis in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 4th Apr 2011, 22:45 -
HD camcorders: AVCHD vs .M2t base format
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2011, 10:44 -
Creating m2ts video and file structure for camcorders and panasonic g10 tvs
By pkitten in forum Video ConversionReplies: 6Last Post: 29th May 2009, 08:21 -
I thought all video editors would take any format and work with it?
By Oldone in forum Newbie / General discussionsReplies: 19Last Post: 15th Jan 2008, 12:10
