Hello,
I have several JVC .MOD (mpg) files that I'm converting to DV format.
When I start ffmpegX and drag in the first file it runs GREAT. When it is
done and I drag in the next file it fails. I have to restart ffmpegX. Is there
some trick to doing mass conversions???? I have to quit and restart ffmpegX
each time.
Thanks,
-Ray
Thread: Can Not Do More Than 1 At A Time
Your source file seems to be DVD compliant MPEG, with a resolution of 704x480. DVD supports both 704x480 and 720x480, but DV wants 720x480, not 704x480.
I think what happens is, that when you enter your 2nd source file, the size gets changed to 704px wide, matching the source, which is non-valid for DV. Re-select the DV preset to change the size to 720px wide (or do it manually in the Video tab). It's faster than quiting and launching again.
It may look like a bug, but it behaves exactly like advertised: (1) Open source file (2) Select preset/settings (3) Encode. You can't skip step 2 for consecutive encodes.
Thank you soooo Much.Originally Posted by Case
-Ray
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
Time of SVCD is double time of source MPG file
By Blues Fan in forum Authoring (VCD/SVCD)Replies: 3Last Post: 12th May 2004, 11:09 -
Help!mux start time is greater than the total time 0 seconds
By sunmanking in forum DVD RippingReplies: 0Last Post: 7th Mar 2004, 08:14 -
Time Shift vs Time Slip vs Playing While Recording
By donpedro in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Jan 2004, 13:48
Statistics
Newest guides
Latest tool updates
New media comments
