Greetings to all. I am posting here to gain some much needed input.
We shoot our first feature film on multiple Canon XL H1 cameras. With being told that these cameras do not shoot true 24P and combined with our straight to DVD model, we went 30P. We are almost finished with our edit and footage looks amazing downconverted to DVD.
I understand that 24P is much easier to convert to 25P PAL. I also understand that 30P can be converted to 60i.
What is the best process to convert from 30P to PAL DVD format? We currently editing in the Cineform codec.
I thank everyone for your time!!!
Edgar Pitts
Jetrefilm Entertainment
Thread: Converting 30P to PAL
option 1: 30p to 50p with MVTools (unless you don't get artifacts specific to your particular video). Then interlace to get true interlaced PAL.
option 2: in AviSynth change FPS to 50 (this adds extra frames that will be use as field source at further interlacing). After interlacing there will be 3 interlaced + 3 progressive frames.
In both cases you use these usual lines for interlacing from 50p:
AssumeTFF().SeparateFields()
SelectEvery(4,0,3).Weave()
Are these high quality (resolution) solutions? Thanks.
Edgar
Yes, these are preferable solutions for fair motion reproduction (no full frame dropping, no blending etc.). Of course, you keep original resolution (option 1 does not always work perfectly, test interpolated frames for each episode). The main problem with interlaced material is that you can't capture perfect stills from it, so do it before conversion if you want them
So the process would be:
Convert 30P to 50P at full resolution (uncompressed AVI) with AviSynth - 1920*1080.
Convert 50P to 50i at full resolution (uncompressed AVI) with AviSynth - 1920*1080.
Downsample and resize to PAL specs in NLE.
A bit different order (resize while it's progressive):
1.Resize + any editing
2.30P to 50P
3.50P to 25i (you drop excessive fields, then weave)
Do you really have 1920*1080 progressive? It's usually interlaced (at least at broadcasting). If interlaced 29.97, then convert it to 59.94p (using LeakKernelDeint filter for AviSynth), change fps to 50, resize and interlace to 25i. Resizing is only necessary for going to standard DVD resolution (HD resolution numbers are the same for PAL).
60i to 30p without re-encoding?
By bobthegoat2001 in forum Camcorders (DV/HDV/AVCHD)Replies: 38Last Post: 30th Sep 2011, 08:55 -
converting from 30i to 30p with Virtualdub; before or after cutting?
By CFPJer in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 22:17 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
hv30 30p question
By minidv2dvd in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 22nd Mar 2009, 22:49 -
HV30 at 30p
By Soopafresh in forum Camcorders (DV/HDV/AVCHD)Replies: 25Last Post: 22nd May 2008, 05:25
