VideoHelp.com Forum
Results 1 to 9 of 9
    Hi All,
    Is anyoune aware of a hardware box that will take a High Definition video signal, in composoit form and output to Firewire?
    I am currently using a canopus ADV 55 with a PAL video camera and getting 720x576 video, but the canopus won't do HD.
    There are two top end canopus boxes that take the HD input but the do not have a firewire output.
    I would look at a PCI card that captures component HD too, if anyone has any suggestion.
    Vert
    Maybe http://www.videoguys.com/mojo.html but looks a bit expensive...
  3. Member edDV's Avatar
    More detail needed for your goals. Do you mean firewire = 720x576 SD? Is the source a set top box?
    Firewire can carry
    - DV stream (720x576)
    - HDV stream (1440x1080 or 1280x720)
    - MPeg2 transport stream (SD or HD)
    - Networked streams or file transfers.
  4. Member Krispy Kritter's Avatar
    ATI's new Tv wonder cards have component inputs, but I haven't used one of them yet.
    Google is your Friend
    HI All
    Thanks for the response, i forgot i had posted this but the issue has come up again.
    I need to get video from a Sony HD block camera, in to a PC.
    I currently use a canopus converter (AVDC-55) to get Standard DVSD and auto into the pc via firwaire. I had to start using the canopus as it the only way to keep the A/V in sync.
    Now i need to do the same but from a HD camera. The camera only has component output. I need to converter to take the audio as well to ensure sync.
    Does anyone have any further suggestions of hardware that can do this?
    Vert
  6. Member edDV's Avatar
    Originally Posted by Vertuas
    HI All
    Vert
    Are you sure you are prepared for the high def bitrate?
    See the discussions of the BlackMagic Intensity Pro.
    Bottom line, a RAID is required for uncompressed capture or a fast computer is needed for real time compression to MJPEG. Cineform compression is a second option.
    The Intensity Pro captures HDMI or component analog to the PCI bus. I'm not aware of an IEEE-1394 solution other than a camera that outputs IEEE-1394. At least not at consumer prices.
    http://www.kiva.org/about
    Hi All,
    Just to update.
    We have rulled out the blakmagic card due to other hardware required to run it. Big old SCSI RAID!!!
    The HDV standard compresses the HD video to mpeg, at a datarate of 25Mbps, same as the DVSD that we capture from the canopus.
    We are yet to find any hardware that windows recognises. Our Sony camcorder can output HD but we can only capture in Premier, with no preview, nothing else even finds the camera in HD mode.
    Thanks Everyone
    Vert
    Originally Posted by Vertuas View Post
    ...box that will take a High Definition video signal, in composoit form and output to Firewire?
    Vert
    Uhh, Vert, there's no such thing as a "composoit" (really spelled composite) connection that supports an HD signal.
    Hi All,
    Just to update.
    Vert
    For 1080p uncompressed, yes. However, 720p using the MJEPG will capture just fine to a clean (defragged) single hard drive.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  1. Firewire device to computer with no Firewire
    By dbuser2 in forum Computer
    Last Post: 24th Sep 2010, 20:32
  2. Sending video to firewire to component.
    By spec09 in forum Video Streaming
    Last Post: 16th Oct 2009, 07:09
  3. HD and upconverting over component?
    By RoyGBiv-inRI in forum DVD & Blu-ray Players
    Last Post: 27th Jul 2009, 19:40
  4. Motherboard Firewire versus Add-in Card Firewire
    By SCDVD in forum Newbie / General discussions
    Last Post: 19th Jun 2008, 11:19
  5. Need USB/Firewire 480p capture over component
    By Try4ce in forum Capturing
    Last Post: 3rd Jan 2008, 15:50
