VideoHelp.com Forum
  1. 1) can I burn 13 gb avi files to blu-ray as a backup?
    2) how much do Blu-ray burners go for?
    3) How much do blu-ray blank disks go for?
    Thank you.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    1. Probably, if you have a Blu-Ray burner and something to play the media back on.
    2. $500 - $600US or more, depending on the brand of Blu-Ray drive.
    3. $15 - $20US per disc, depending on where you buy it.
    And being that even dual layer DVD discs seem to only marginally work at times, and only with a few brand discs and burners, I don't know that I would even try Blu-Ray until the format is a bit more developed.
  3. I want to back up my video avi tapes that have 13gb each, so this sounds like an excellent way to do it? Are people backing up this way?
  4. No they are not. HDD space is cheap...take advantage of it. You could get close to 2 Terabytes of HDD space for all that cash.
  5. with bluray you can burn data like PC files & prgrams on it like you would burn the same on a DVD data disk?
  6. Member yoda313's Avatar
    Yes. Though I don't have one bluray is nothing more than a dvd on steroids essentially - as far as digital data is concerned. Just more space.
    But the other members are probably on the right track. You might find it better long term to invest in larger harddrives. That way you won't sacrifice quality or potential loss of data.
  7. Member edDV's Avatar
    If you had a BluRay burner you could back ~111 minutes of DV format for ~$25 per blank. Or you could backup to hard drive or MiniDV tapes. 63min MiniDV tapes are down to less than $2.50.
    http://www.kiva.org/about
  8. Member Cornucopia's Avatar
    ...Or you could us Virtualdub and segment your AVI into 4.37GB chunks and burn to 3 standard DVD-Rs for a total of $0.90.
  1. Blu-Ray cover questions
    By THX-UltraII in forum Media
    Last Post: 30th Mar 2012, 19:56
  2. newbie blu ray question
    By cividan in forum DVD & Blu-ray Writers
    Last Post: 16th Oct 2011, 19:22
  3. newbie to blu-ray to avi. help.
    By babeflover in forum Blu-ray Ripping
    Last Post: 12th Oct 2010, 10:16
  4. Newbie Help ripping blu ray
    By DravenJ in forum Blu-ray Ripping
    Last Post: 8th Jun 2010, 07:50
  5. new to blu-ray 2 questions
    By uglijimus in forum DVD & Blu-ray Players
    Last Post: 11th May 2010, 23:43
