    Apr 2005
    Massachusetts
    Is there a way to just clip a video to a certain length with ffmpegX (or command line directions, I guess)?
    I have an mpeg2 that I just want to clip off the last few minutes or so. I see the 'split' and 'join' options, but to get reasonably approaching the length I want may require a variety of strategic operations. Is there just a way to clip a video to a certain length? If not, is there some other open source/freeware utility that will do this?
    - Fred
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    The ffmpegX Split tool is time based.
    The MPEG Streamclip Save Selection tool is visual, if you have the QuickTime MPEG-2 Playback Component.
    I am not aware of an MPEG cutter that cuts on specified file size, if that's what you're looking for.
    Aug 2005
    Palo Alto, California USA
    I am not at all certain about this, but ISTR that MoreMissingMPEGTools can split either at specified time boundaries or at certain filesize boundaries. In any case, it's free:
    http://www.angelfire.com/mac/rnc/files/MoreTools.html
    So, if it doesn't do what you want, at least you haven't wasted any money. And it's a good thing to have in any case (as are the other tools in his suite).
