I have some MKV files that i need to convert to WMV/WMVHD or to a dvd formated ISO. The problem i have is I play all my movies from my HTPC using MCE/My Movies Plugin that doesnt support mkv.
Any suggestions as to which programs that will do this for me and still keep the quality high?
Thanks for any responses.
Thread: MKV/264 to WMV/WMVHD/ISO
Best recommendation? Demux the mkv and combine it to AVI using VirtualDub. There is a tutorial somewhere around here.Originally Posted by ironape2MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
ConvertXtoDVD can convert to DVD and I think AutoMKV supports MKV to WMVHD conversion.
But it's not worth converting, you will probabaly get sync problems and it will take years to convert. Can't you run a separate video player in MCE?
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 20:50 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 11:41 -
Flash (H.264) vs WMV streaming
By kameel in forum Video StreamingReplies: 1Last Post: 15th Dec 2008, 18:06 -
Can you convert x.264 to WMV-HD via MovieMaker ?
By Raycaster in forum Video ConversionReplies: 0Last Post: 6th Jan 2008, 17:07 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
