Apologies!!
I want to start off by saying I am totally sorry if this has been posted. Iread the rules, did a search but couldnt find anything. I am a TOTAL beginner at this so with that said. I intalled the AVStoDVD software made sure AviSynth was intalled, and when I try to run AVStoDVD, I get the following error:
"Warning! AviSynth NOT found!
Most of encoding routines will not be available!"
Can someone please advise on this. What exactly is the fix for this?!
Results 61 to 90 of 833
Thread: AVStoDVD Support Thread
Stupid me. Thanks eskro, it wasnt in the same directory as avstodvd. I reinstalled it in the same directory, problem solved.
Super!!
Ok i have another issue. I just used AVStoDVD for a movie (.mkv) an noticed it has DTS for audio. I went to sleep can back and these are the results.
I have 5 files:
1st file - The.Last.House.On.The Left_0 (Which contain the Audio_TS & Video_TS files)
2nd file -The.Last.House.On.The.Left.UNRATED.2009.720p.BDRip .x264-GP.dts
3rd file - The.Last.House.On.The Left_0.log
4th file - The Last House On The Left.a2d
5th file - The Last House on The Left_0.log
Question, how am I not supposed to burn this to a DVD?
Yea I know It didnt maybe i have to tweak some settings? Could I still burn the existing files (output) I have now?
Im gonna redo it
Ok now its been stuck at the preparing image stage (Video_TS) for over 2 hours at 33%. What are the correct settings? I still must be doing something wrong. Im simply trying to creat a dvd out of this.
I replied
OK, now this is just crazy. I finally got the dvd to burn, came out nice and clear, but now.......NO SOUND!! Im at a loss!!
Mr. C. As you wish..........
<2/27/2010 11:49:49 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 7911/8300 MB (95%)
DVD Output Setup: Burn DVD
DVD Label: The Last House on The Left
DVD Menu: No Menu
Output Folder: G:\The.Last.House.On.The Left
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliat Audio: 1
Normalize Audio: 1
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: K: TSSTcorp CDDVDW SH-S223L SB01
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: F:\P_6\The.Last.House.On.The.Left.UNRATED.720p.Blu Ray.x264-HUBRIS\lhotl-hurbis.mkv
Info: AVC - 6590 kbps - 1280x696 - DAR 1.839 - 23.976 fps (CFR) - Progressive - 1:53:31 hours - 163464 frames
Audio: F:\P_6\The.Last.House.On.The.Left.UNRATED.720p.Blu Ray.x264-HUBRIS\lhotl-hurbis.mkv
Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:53:37 hours
Subs:
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("F:\P_6\The.Last.House.On.The.Left. UNRATED.720p.BluRay.x264-HUBRIS\lhotl-hurbis.mkv", CacheFolder = "C:\Users\Kayizm1\AppData\Local\Temp")
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("F:\P_6\The.Last.House.On.The.Left. UNRATED.720p.BluRay.x264-HUBRIS\lhotl-hurbis.mkv", CacheFolder = "C:\Users\Kayizm1\AppData\Local\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown to upsize FPS
Video = Video.AddBorders(0,12,0,12)
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 6472.9 MB
QuEnc Parameters: -i "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_The Last House on The Left.avs" -o "G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.m2v" -b 7964 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<2/27/2010 1:58:02 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.m2v (6472.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7964 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:53:30 hours - 163299 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<2/27/2010 2:04:31 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.m2v (6472.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7964 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:53:37 hours - 163460 frames
<2/27/2010 2:04:32 PM>
START AUDIO DEMUXING OPERATIONS
FFmpeg Parameters: -i "F:\P_6\The.Last.House.On.The.Left.UNRATED.720p.Bl uRay.x264-HUBRIS\lhotl-hurbis.mkv" -acodec copy "G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.ToFix.dts"
<2/27/2010 2:07:34 PM>
END AUDIO ENCODING OPERATIONS
Created File: G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.dts (1226.4 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:53:34 hours
<2/27/2010 2:07:35 PM>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_BatchMux.ini"
BatchMux ini file:
-d "G:\The.Last.House.On.The Left\The Last House on The Left_0\VIDEO_TS"
-mxp "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_MuxMan.mxp"
-l "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.m2v"
-vidmode LB
-a1 "G:\The.Last.House.On.The Left\The Last House on The Left_0_The Last House on The Left.dts"
-a1lang en
-cellfr "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_The Last House on The Left_MuxMan.txt"
-progfr "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_The Last House on The Left_MuxMan.txt"
-chapfr "C:\Users\Kayizm1\AppData\Local\Temp\The Last House on The Left_0_The Last House on The Left_MuxMan.txt"
<2/27/2010 2:15:00 PM>
END DVD AUTHORING OPERATIONS
Created Folder: G:\The.Last.House.On.The Left\The Last House on The Left_0 (6596.9 MB)
START DVD BURNING OPERATIONS
ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "G:\The.Last.House.On.The Left\The Last House on The Left_0\VIDEO_TS" /dest K: /volumelabel "The Last House on The Left" /speed 4x /erase /testmode no /verify no /noimagedetails /start /waitformedia /close
<2/28/2010 12:12:39 PM>
END DVD BURNING OPERATIONS
Created DVD: 'The Last House on The Left' in drive K: TSSTcorp CDDVDW SH-S223L SB01
Log file created by AVStoDVD Release 2.2.6
MuxMan (the authoring software) has not accepted the DTS audio stream, kept from input file.
You can try to force audio re-encoding (to AC3). Go to 'Title Edit'/'Audio', toggle off 'Auto Audio Setup' and 'Keep DVD compliant Audio'.
Let me know
Bye
I got it to work. Thanks that helped.
OK ill leave you with one more . LOL I have this foreign movie (.mkv) and it has subtitles. but when doing my editing within AVS, it tells me "Subtitles not present." If i play the movie within VLC player it automaticly shows me the english subtitles? I want to have these english subtitles present. What do I do in a case like this?
awesome tool! one thing I didn't see an option for..my videos are 59.94 (60i) from a canon vixia hf10 so they encoded as such..but when the mpeg is played back It plays at double speed..or like it's playing 60i at 30p. Is there an option somewhere for setting it to 29.97 instead? I thought maybe editing the avisynth script using
Video = Video.selecteven() would fix it but it may have made it worse :P.
Yep, it is a little bug that will be solved since next release. The Selecteven() workaround is perfect.
From the Help section:
Source Titles SectionIf source file contains more than 1 Subtitles track, AVStoDVD will ask for track selection, with the option (mandatory) to demux it. This option is avaliable only for Matroska containers and only if MKVExtract (part of MKVToolnix package) is found in the current system.
Bye
well..the problem is selecteven() changes it to 29.97, but the video still plays at 2x speed
. I just need to know how to edit the avisynth script it creates. do the parameters in :SeparateFields().SelectEvery(4,1,2).Weave()" need to be changed? I'm sure it's doing exactly what it's being told to do, just not what I want it to do
Not sure about that. You can try to deinterlace the video. You find the deinterlacing option in the AviSynth Tab.
Could you upload a small clip sample?
Bye
Bye[/QUOTE]
MrC.
Here are the logs that generated. I got errors in using the tools you suggested.
The Elite Squad_0.log
<3/4/2010 8:40:20 AM>
START PROCESS
PROJECT SETTINGS
DVD Size: 7538/8300 MB (91%)
DVD Label: The Elite Squad
DVD Menu: No Menu
Output Folder: G:\Elite Squad
PREFERENCES
Video Resolution: 0
DVD Audio Format: 0
Keep DVD Compliat Audio: 0
Normalize Audio: 0
Save Log file: 1
Video: F:\P_6\Elite.Squad.2007.LiMiTED.720p.Bluray.x264-SEPTiC\elitesquad-septic.mkv
Info: AVC - 6498 kbps - 1280x696 - DAR 1.839 - 23.976 fps (CFR) - Progressive - 1:54:37 hours - 165048 frames
Audio: F:\P_6\Elite.Squad.2007.LiMiTED.720p.Bluray.x264-SEPTiC\elitesquad-septic.mkv
Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:54:43 hours
Subs: G:\Elite Squad\elitesquad-septic.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\P_6\Elite.Squad.2007.LiMiTED.72 0p.Bluray.x264-SEPTiC\elitesquad-septic.mkv", CacheFolder = "C:\Users\Kayizm1\AppData\Local\Temp")
Audio = A2DAudioSource("F:\P_6\Elite.Squad.2007.LiMiTED.72 0p.Bluray.x264-SEPTiC\elitesquad-septic.mkv", CacheFolder = "C:\Users\Kayizm1\AppData\Local\Temp")
Audio = Audio.Normalize()
Target Video FileSize: 6975.4 MB
QuEnc Parameters: -i "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic.avs" -o "G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<3/4/2010 11:33:45 AM>
Created File: G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v (6914.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:53:37 hours - 163449 frames
DGPulldown Parameters: "G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<3/4/2010 11:41:10 AM>
DGPulldown executed on File: G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v (6914.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:53:43 hours - 163611 frames
START AUDIO ENCODING OPERATIONS
Wavi+Aften Parameters: "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "G:\Elite Squad\The Elite Squad_0_elitesquad-septic.ac3"
<3/4/2010 11:48:29 AM>
A2DAudioSource: DirectShowSource
Created File: G:\Elite Squad\The Elite Squad_0_elitesquad-septic.ac3 (364.4 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 48000Hz - 4ch - 1:53:44 hours
<3/4/2010 11:48:34 AM>
START SUBS ENCODING OPERATIONS
SubtitleCreator Parameters: "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic.srt" -p4 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO"
<3/4/2010 11:49:08 AM>
END SUBS ENCODING OPERATIONS
Created File: G:\Elite Squad\The Elite Squad_0_elitesquad-septic.sup (3.8 MB)
BatchMux Parameters: -arglist "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_BatchMux.ini"
BatchMux ini file:
-d "G:\Elite Squad\The Elite Squad_0\VIDEO_TS"
-mxp "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_MuxMan.mxp"
-l "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_MuxMan.log"
-prio LOW
-v "G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v"
-vidmode LB
-a1 "G:\Elite Squad\The Elite Squad_0_elitesquad-septic.ac3"
-a1lang en
-s1 "G:\Elite Squad\The Elite Squad_0_elitesquad-septic.sup"
-s1lang en
-cellfr "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic_MuxMan.txt"
-progfr "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic_MuxMan.txt"
-chapfr "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic_MuxMan.txt"
<3/4/2010 3:50:43 PM>
PROCESS ABORTED DURING DVD AUTHORING OPERATIONS!
CHECK FOLLOWING FILES FOR MORE DETAILS:
AVSTODVD LOG FILE <G:\ELITE SQUAD\THE ELITE SQUAD_0.LOG>
BATCHMUX LOG FILE <G:\ELITE SQUAD\THE ELITE SQUAD_0_BATCHMUX.LOG>
<3/4/2010 3:50:47 PM>
and also
The Elite Squad_0_BatchMux.log
BatchMux version --> 1.3
Destination Folder --> G:\Elite Squad\The Elite Squad_0\VIDEO_TS
MuxMan Script File --> C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_MuxMan.mxp
MuxMan Log String --> -l "C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_MuxMan.log"
Folder of the MuxMan executable --> C:\Program Files\AVStoDVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Segment #1 - Video File #1 --> G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v
Checking asset for importing as --> M2V, M1V, MPV
Video Coding Mode --> MPEG-2
Video Resolution (Nominal) --> (720x480)
MPEG-2 Aspect Ratio (DAR) --> 16:9
Video Frame Rate --> 29,97 fps
Video Bitrate (Nominal, Kbps) --> 8300
VBV Buffer Size (Kbyte) --> 224
Segment #1 - Video Display Mode --> LB
Segment #1 - Audio #1 File #1 --> G:\Elite Squad\The Elite Squad_0_elitesquad-septic.ac3
Segment #1 - Audio Lang Code #1 --> en
Segment #1 - Subpicture File #1 --> G:\Elite Squad\The Elite Squad_0_elitesquad-septic.sup
Segment #1 - Subpic Lang Code #1 --> en
Segment #1 - Timeframe file --> C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_elitesquad-septic_MuxMan.txt
Segment #1 - Total Nr of Cells --> 23
Segment #1 - Total Nr of Programs --> 23
Segment #1 - Total Nr of Chapters --> 23
Started preparation of --> MUXMAN SCRIPT
Completed preparation of --> MUXMAN SCRIPT
MuxMan RunString --> -run
Strings (local stack - bytes) --> 1098
Time Codes (local heap - bytes) --> 841
Static memory usage % --> 1.48
Starting MuxMan Authoring with --> LOW task priority
MuxMan Authoring --> COMPLETE
Printing out --> MUXMAN LOG
-- MuxMan version 0.15R
-- Opened script file C:\Users\Kayizm1\AppData\Local\Temp\The Elite Squad_0_MuxMan.mxp
-- Accepted video G:\Elite Squad\The Elite Squad_0_elitesquad-septic.m2v size = 2955542136
-- Accepted audio G:\Elite Squad\The Elite Squad_0_elitesquad-septic.ac3
-- Opened sub 1 file G:\Elite Squad\The Elite Squad_0_elitesquad-septic.sup.
-- 12:04:30 Begin multiplex VTS01.
-- Title Segment List
-- Seg1
-- Encoded stream 20 is script stream 1.
-- Maximum audio duration 409032 fields.
-- Starting scene Seg1_Scn1 at 00:00:00:00
-- Starting scene Seg1_Scn2 at 00:05:00:12, requested for 00:05:00:00
-- Starting scene Seg1_Scn3 at 00:10:00:09, requested for 00:10:00:00
-- Starting scene Seg1_Scn4 at 00:15:00:12, requested for 00:15:00:00
-- Starting scene Seg1_Scn5 at 00:20:00:01, requested for 00:20:00:00
-- Starting scene Seg1_Scn6 at 00:25:00:05, requested for 00:25:00:00
-- Starting scene Seg1_Scn7 at 00:30:00:12, requested for 00:30:00:00
-- Starting scene Seg1_Scn8 at 00:35:00:01, requested for 00:35:00:00
-- Starting scene Seg1_Scn9 at 00:40:00:12, requested for 00:40:00:00
-- Starting scene Seg1_Scn10 at 00:45:00:01, requested for 00:45:00:00
-- Starting scene Seg1_Scn11 at 00:50:00:12, requested for 00:50:00:00
-- Starting scene Seg1_Scn12 at 00:55:00:05, requested for 00:55:00:00
-- Starting scene Seg1_Scn13 at 01:00:00:05, requested for 01:00:00:00
-- Starting scene Seg1_Scn14 at 01:05:00:01, requested for 01:05:00:00
-- Starting scene Seg1_Scn15 at 01:10:00:01, requested for 01:10:00:00
-- Starting scene Seg1_Scn16 at 01:15:00:12, requested for 01:15:00:00
-- Starting scene Seg1_Scn17 at 01:20:00:12, requested for 01:20:00:00
-- Starting scene Seg1_Scn18 at 01:25:00:09, requested for 01:25:00:00
-- Starting scene Seg1_Scn19 at 01:30:00:01, requested for 01:30:00:00
-- Starting scene Seg1_Scn20 at 01:35:00:05, requested for 01:35:00:00
-- Starting scene Seg1_Scn21 at 01:40:00:01, requested for 01:40:00:00
-- P-STD buffer underflow by 14685 bytes at 565452654, sector 3491342.
-- Starting scene Seg1_Scn22 at 01:45:00:05, requested for 01:45:00:00
-- Starting scene Seg1_Scn23 at 01:50:00:09, requested for 01:50:00:00
-- End of video file
-- Bytes remaining in buffer = 14685.
-- Bitrate - avg: 9104419, min: 7267228 (lba 3623285), max: 11031784 (lba 3490924).
-- Shortest GOP has 7 fields, longest GOP has 30 fields.
-- Fields: 409033, VOBU: 13208, Sectors: 3792045.
-- Video decoder buffer underflowed 1 times.
-- Check c:\muxman.log for details.
-- Resulting DVD will probably not play smoothly.
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
Any suggestions?
From Muxman error log:
QuEnc has generated some bitrate spikes. You can either decrease the title video avg bitrate (from 8500 to 7500/8000 kbps) or switch to HCenc, which has better bitrate control routines.Code:-- Bitrate - avg: 9104419, min: 7267228 (lba 3623285), max: 11031784 (lba 3490924). -- Shortest GOP has 7 fields, longest GOP has 30 fields. -- Fields: 409033, VOBU: 13208, Sectors: 3792045. -- Video decoder buffer underflowed 1 times. -- Check c:\muxman.log for details. -- Resulting DVD will probably not play smoothly.
Bye
Hi MrC, thanks for your hard work on AVStoDVD. A few months ago some of us alerted you to an issue concerning the resizing of interlaced material which was damaging quality. Has AVStoDVD been updated to fix this?
I noticed greymalkin mentioned "SeparateFields().SelectEvery(4,1,2).Weave()" being in the generated AVS script, which looks like a reinterlacing action. Is the resizing done before the reinterlacing?
@creamyhorror
Yes, my friend, interlaced material resizing routine has been improved since release 2.2.2.
Just feed an interlaced source and have some resizing effects.
Let me know
Bye
Hello, my name is Viviana, I am writing from Argentina, I am using a translator not write English.I spend a blu ray to dvd, I was enchanted with the image, but my second attempt was with the UP and blu ray came out a sign telling me that there were two picturesin one file so only select one of the two and I copy half of the movie.
my third test was another movie by adding captions but something happened and I found many errors, change various settings, even crash the program. I delete, reinstall it and try with another movie without subtitles but I can not work anymore, the program hangs. I hope can help me, I'd love to use your program because I find it very interesting.
Enclosed are the records of the failures.
Thank you very much
VIVIANA
<20/03/2010 10:35:57 p.m.>
START PROCESS
PROJECT SETTINGS
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: ISO UDF Image
DVD Label: DVD
DVD Menu: No Menu
Output Folder: L:
PREFERENCES
Video Resolution: 0
AC3 Audio Encoder: 2
DVD Audio Format: 0
DVD Audio BitRate: 192
Normalize Audio: 0
DVD Audio Language: ES - Spanish
DVD Subs Language: ES - Spanish
DVD Burning Drive: D: ATAPI iHAS120 6 7L0E
Save Log file: 1
Video: L:\WATERHORSE\BDMV\STREAM\00011.m2ts
Info: AVC - 0 kbps - 1920x1080 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:51:48 hours - 160847 frames
Audio: L:\WATERHORSE\BDMV\STREAM\00011.m2ts
Info: TrueHD - 0 kbps - VBR / CBR - 48000Hz - 6ch - 1:51:48 hours - Track 0
Subs:
AVISYNTH SCRIPT
Import("C:\Archivos de programa\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("L:\WATERHORSE\BDMV\STREAM\00011.m2 ts", CacheFolder = "C:\DOCUME~1\C2D\CONFIG~1\Temp")
Audio = A2DAudioSource("L:\WATERHORSE\BDMV\STREAM\00011.m2 ts", CacheFolder = "C:\DOCUME~1\C2D\CONFIG~1\Temp")
Audio = Audio.GetChannel(1,3,2,5,6,4)
<20/03/2010 10:36:17 p.m.>
Encoding Profile: HCenc OPV 1-pass
Target Video FileSize: 4190,8 MB
HCenc Parameters: -ini "C:\DOCUME~1\C2D\CONFIG~1\Temp\DVD_0_00011.HCenc.i ni"
HCenc ini file:
*INFILE C:\DOCUME~1\C2D\CONFIG~1\Temp\DVD_0_00011.avs
*AVSRELOAD
*OUTFILE L:\DVD_0_00011.m2v
*LOGFILE C:\DOCUME~1\C2D\CONFIG~1\Temp\DVD_0_00011.HCenc.lo g
*MAXBITRATE 9000
*CQ_MAXBITRATE 1
*BITRATE 5240
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<20/03/2010 10:36:37 p.m.>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <L:\DVD_0.LOG> FOR MORE INFO.
Other
<20/03/2010 11:02:12 p.m.>
START PROCESS
PROJECT SETTINGS
DVD Label: PRUEBA
DVD Menu: No Menu
Output Folder: L:\PRUEBA
PREFERENCES
AVS Source Filter: AVISource
Video Resolution: 0
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Subs:
<>Last edited by Rosetta; 21st Mar 2010 at 11:56.
It could be related to your directshow audio filter output mixer. Since you are encoding a 5.1 channels audio, you should setup it as 3/0/2+LFE.
Bye
No where do I find it is very unusual because in the first test to perform the audio recording in 5.1, except that he had not put the subtitle, but could hear very well. Program that all who are charged together with me this AVStoDVD impede the process? but do tell me how to completely uninstall and re-upload? Thanks and apologies I'm very new at this.
I suggest you to uninstall every directshow codec you have installed and use only ffdshow, that cover 99% of codecs.
About your first successful trial, maybe you did use Wavi+Aften as AC3 encoder and not QuEnc. QuEnc needs a GetChannel() call that forces the previous setup of AC3 filter mixer.
Bye
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 675Last Post: 6th May 2012, 01:04 -
TEncoder - Multithreaded GUI for FFMpeg and Mencoder (Support thread)
By ozok in forum Video ConversionReplies: 28Last Post: 22nd Apr 2012, 20:12 -
Hybrid [x264/XViD - MKV/MP4] Converter Support Thread
By Bonie81 in forum Video ConversionReplies: 0Last Post: 5th Nov 2011, 19:58 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37 -
Start product support thread?
By midders in forum FeedbackReplies: 2Last Post: 4th Aug 2009, 14:15
