Results 721 to 750 of 833
Thread: AVStoDVD Support Thread
Thanks for the help all! Im surprised to find myself reporting such specialized problems and then realizing I found a bug in the program. I feel so special
I have been having good luck now only using MP2 to convert audio. Usually using either quenc or FFMpeg for the Audio decoder. I will report back when I run into any other problems.
Hello,
I need some help. AVStoDVD keep crashing when it gets to the authoring stage. I have installed AVStoDVD 2.4.1 with ffdshow beta 7. No other codecs installed. I would really like to use this program as the menu wizard is just brilliant! Thanks in advance. Here is the log file.
<2/3/2012 12:36:48 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 4
DVD Size: 4249/4450 MB (95%)
DVD Output Setup: DVD Folder
DVD Label: EP_1_TO_3
DVD Menu: Motion Menu
Output Folder: C:\Documents and Settings\Owner\My Documents\My Videos
Delete Temp Process Files: No
Delete Working Files: No
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 10
Use Source Chapters: 1
DVD Burning Drive: F: SONY CD-RW CRX320EE RYK4
DVD Burning Speed: 4x
Auto Erase DVD RW: 0
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: C:\DW 5 Ep 1 to 3\E1.avi
Info: DivX 5 - 1868 kbps - 640x364 - DAR 1.758 - 25 fps (CFR) - Progressive - 1:02:35 hours - 93897 frames
Audio 1: C:\DW 5 Ep 1 to 3\E1.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 1:02:35 hours (0 ms delay) - Internal
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\DW 5 Ep 1 to 3\E1.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\DW 5 Ep 1 to 3\E1.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Lanczos4Resize(720,480,0,2,0,-2)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 1560 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.HCenc.log
*MAXBITRATE 9000
*BITRATE 3484
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 2:56:32 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: AVISource
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.m2v (1560.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 1:02:35 hours - 93897 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 3:00:05 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.m2v (1560.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 1:02:35 hours - 112561 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_1.ac3"
<2/3/2012 3:01:58 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
A2DAudioSource: DirectShowSource
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_1.ac3 (86 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:02:35 hours (0 ms delay)
TITLE 2 SOURCE FILES
Video: C:\DW 5 Ep 1 to 3\E2.avi
Info: DivX 5 - 1564 kbps - 640x364 - DAR 1.758 - 25 fps (CFR) - Progressive - 41:26 minutes - 62172 frames
Audio 1: C:\DW 5 Ep 1 to 3\E2.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 41:26 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\DW 5 Ep 1 to 3\E2.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\DW 5 Ep 1 to 3\E2.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Target Video FileSize: 1032.9 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.HCenc.log
*MAXBITRATE 9000
*BITRATE 3484
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 4:19:04 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.m2v (1033.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 41:26 minutes - 62172 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 4:21:23 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.m2v (1033.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 41:26 minutes - 74528 frames
<2/3/2012 4:21:25 PM>
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_1.ac3"
<2/3/2012 4:22:53 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_1.ac3 (56.9 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 41:26 minutes (0 ms delay)
TITLE 3 SOURCE FILES
Video: C:\DW 5 Ep 1 to 3\E3.avi
Info: DivX 5 - 1736 kbps - 640x364 - DAR 1.758 - 25 fps (CFR) - Progressive - 41:15 minutes - 61897 frames
Audio 1: C:\DW 5 Ep 1 to 3\E3.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 41:15 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\DW 5 Ep 1 to 3\E3.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\DW 5 Ep 1 to 3\E3.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Target Video FileSize: 1028.3 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.HCenc.log
*MAXBITRATE 9000
*BITRATE 3484
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 5:39:32 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.m2v (1029 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 41:15 minutes - 61897 frames
<2/3/2012 5:39:33 PM>
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 5:41:55 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.m2v (1029 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 41:15 minutes - 74199 frames
<2/3/2012 5:41:57 PM>
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_1.ac3"
<2/3/2012 5:43:19 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_1.ac3 (56.6 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 41:15 minutes (0 ms delay)
TITLE 4 SOURCE FILES
Video: C:\DW 5 Ep 1 to 3\X1.avi
Info: DivX 5 - 1649 kbps - 640x360 - DAR 1.778 - 25 fps (CFR) - Progressive - 10:12 minutes - 15323 frames
Audio 1: C:\DW 5 Ep 1 to 3\X1.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 10:12 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\DW 5 Ep 1 to 3\X1.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\DW 5 Ep 1 to 3\X1.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Video = Video.Lanczos4Resize(720,480)
Target Video FileSize: 254.6 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.HCenc.log
*MAXBITRATE 9000
*BITRATE 3484
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 6:01:24 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.m2v (254.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 10:12 minutes - 15323 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 6:01:46 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.m2v (254.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 10:12 minutes - 18368 frames
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_1.ac3"
<2/3/2012 6:02:05 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_1.ac3 (14 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 10:12 minutes (0 ms delay)
<2/3/2012 6:02:06 PM>
START DVD MENU BUILDING OPERATIONS
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: DW5
Max Titles Page: 12
Enable Play All: 0
Force Play All: 0
Background Audio: 1
Max Thumbs Row: 4
Thumb Image Source: 0
Thumb Frame Position: 10%
HL Frame Format: 1
HL Selection Color: 16
HL Play Color: 0
Menu Video BitRate: 3500 kbps
Motion Menu Duration: 60 seconds
Thumb Drop Shadow: 2
Play All Shadow: 2
Arrows Shadow: 0
<2/3/2012 6:08:20 PM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_MenuPage1.m2v (25 MB)
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Menu.ac3 (1.4 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_BatchMux.ini"
BatchMux ini file:
-d "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0\VIDEO_TS"
-mxp "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_MuxMan.mxp"
-l "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Palette.txt"
-v "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_1.ac3"
-a1lang en
-cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_Chapters.txt"
-progfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_Chapters.txt"
-chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_01_E1_Chapters.txt"
-SEG2v "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_1.ac3"
-SEG2a1lang en
-SEG2cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_Chapters.txt"
-SEG2progfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_Chapters.txt"
-SEG2chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_02_E2_Chapters.txt"
-SEG3v "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3.m2v"
-SEG3vidmode LB
-SEG3a1 "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_1.ac3"
-SEG3a1lang en
-SEG3cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_Chapters.txt"
-SEG3progfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_Chapters.txt"
-SEG3chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_03_E3_Chapters.txt"
-SEG4v "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1.m2v"
-SEG4vidmode LB
-SEG4a1 "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_1.ac3"
-SEG4a1lang en
-SEG4cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_Chapters.txt"
-SEG4progfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_Chapters.txt"
-SEG4chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Title_04_X1_Chapters.txt"
-SEG5v "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_MenuPage1.m2v"
-SEG5vidmode LB
-SEG5a1 "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Menu.ac3"
-SEG5s1 "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_Menu.sst"
-SEG5s1dmode WIDE_LB
-SEG5hlmnu "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_MenuPage1_Buttons.mnu"
-SEG5hlcsm "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_HighlightScheme.csm
-hcn "C:\Documents and Settings\Owner\My Documents\My Videos\EP_1_TO_3_0_BatchMux.hcn"
<2/3/2012 6:08:29 PM>
ERROR DURING OPERATIONS ('DVD Authoring operations' Section): 0 -
PROCESS ABORTED.
Log file created by AVStoDVD Release 2.4.1
For some reason MuxMan (the authoring sw) cannot write on output destination. I would suggest to try to change the Output from 'C:\Documents and Settings\Owner\My Documents\My Videos' to somewhere else, better if on another drive partition (if any).
Bye
Thanks for your reply MrC. I tried your suggestions, changing the output to "E:". I had the same results. I then put the source files on "D:", so that AVStoDVD is on C drive, source files are on D drive, output is on E drive. It still fails on muxing. I have all of the working files if anything else could help diagnose the problem. Thanks for your help. Here is the only log file generated.
DVD_0.log
<2/4/2012 3:02:50 PM>
START PROCESS
PROJECT SETTINGS
DVD Size: 4277/4450 MB (96%)
DVD Label: DVD
Output Folder: E:
PREFERENCES
MultiThread: 1
Video Resolution: 1
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
Save Log file: 1
Video: D:\E1.m2v
Info: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 1:02:35 hours - 112561 frames
Audio 1: D:\E1_1.ac3
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 1:02:35 hours (0 ms delay) - External
[MediaInfoLib - v0.7.47]
AVISYNTH SCRIPT
# Video is frameserved by AviSynth just for Preview and Edit purposes.
Video = A2DVideoSource("D:\E1.m2v", CacheFolder="E:", FrameRate=29.97, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("D:\E1_1.ac3", CacheFolder="E:")
START VIDEO DEMUXING OPERATIONS
Target Video FileSize: 1570.7 MB
FFmpeg Parameters: -i "D:\E1.m2v" -vcodec copy "E:\DVD_0_Title_01_E1.m2v"
<2/4/2012 3:03:47 PM>
Created File: E:\DVD_0_Title_01_E1.m2v (1560.9 MB)
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "D:\E1_1.ac3" -acodec copy "E:\DVD_0_Title_01_E1_1.ToFix.ac3"
<2/4/2012 3:04:02 PM>
Created File: E:\DVD_0_Title_01_E1_1.ac3 (86 MB)
Video: D:\E2.m2v
Info: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 41:26 minutes - 74528 frames
Audio 1: D:\E2_1.ac3
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 41:26 minutes (0 ms delay) - External
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\E2.m2v", CacheFolder="E:", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("D:\E2_1.ac3", CacheFolder="E:")
Target Video FileSize: 1040 MB
FFmpeg Parameters: -i "D:\E2.m2v" -vcodec copy "E:\DVD_0_Title_02_E2.m2v"
<2/4/2012 3:04:34 PM>
Created File: E:\DVD_0_Title_02_E2.m2v (1033.5 MB)
FFmpeg Parameters: -i "D:\E2_1.ac3" -acodec copy "E:\DVD_0_Title_02_E2_1.ToFix.ac3"
<2/4/2012 3:04:44 PM>
Created File: E:\DVD_0_Title_02_E2_1.ac3 (56.9 MB)
Video: D:\E3.m2v
Info: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 41:15 minutes - 74199 frames
Audio 1: D:\E3_1.ac3
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 41:15 minutes (0 ms delay) - External
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\E3.m2v", CacheFolder="E:", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("D:\E3_1.ac3", CacheFolder="E:")
Target Video FileSize: 1035.4 MB
FFmpeg Parameters: -i "D:\E3.m2v" -vcodec copy "E:\DVD_0_Title_03_E3.m2v"
<2/4/2012 3:05:16 PM>
Created File: E:\DVD_0_Title_03_E3.m2v (1029 MB)
FFmpeg Parameters: -i "D:\E3_1.ac3" -acodec copy "E:\DVD_0_Title_03_E3_1.ToFix.ac3"
<2/4/2012 3:05:26 PM>
Created File: E:\DVD_0_Title_03_E3_1.ac3 (56.6 MB)
Video: D:\X1.m2v
Info: MPEG-2 Video - 3508 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 10:12 minutes - 18368 frames
Audio 1: D:\X1_1.ac3
Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 10:12 minutes (0 ms delay) - External
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\X1.m2v", CacheFolder="E:", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("D:\X1_1.ac3", CacheFolder="E:")
Target Video FileSize: 256.3 MB
FFmpeg Parameters: -i "D:\X1.m2v" -vcodec copy "E:\DVD_0_Title_04_X1.m2v"
<2/4/2012 3:05:34 PM>
Created File: E:\DVD_0_Title_04_X1.m2v (254.7 MB)
<2/4/2012 3:05:35 PM>
FFmpeg Parameters: -i "D:\X1_1.ac3" -acodec copy "E:\DVD_0_Title_04_X1_1.ToFix.ac3"
<2/4/2012 3:05:38 PM>
Created File: E:\DVD_0_Title_04_X1_1.ac3 (14 MB)
<2/4/2012 3:05:39 PM>
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: Dr Who Series 5
Max Titles Page: 12
Enable Play All: 0
Force Play All: 0
Background Audio: 1
Max Thumbs Row: 4
HL Frame Format: 1
HL Play Color: 0
Play All Shadow: 2
Arrows Shadow: 0
<2/4/2012 3:12:17 PM>
Created File (Menu Page 1): E:\DVD_0_MenuPage1.m2v (25 MB)
Created File: E:\DVD_0_Menu.ac3 (1.4 MB)
BatchMux Parameters: -arglist "E:\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD_0\VIDEO_TS"
-mxp "E:\DVD_0_MuxMan.mxp"
-l "E:\DVD_0_MuxMan.log"
-prio LOW
-palette "E:\DVD_0_Palette.txt"
-v "E:\DVD_0_Title_01_E1.m2v"
-vidmode LB
-a1 "E:\DVD_0_Title_01_E1_1.ac3"
-a1lang en
-cellfr "E:\DVD_0_Title_01_E1_Chapters.txt"
-progfr "E:\DVD_0_Title_01_E1_Chapters.txt"
-chapfr "E:\DVD_0_Title_01_E1_Chapters.txt"
-SEG2v "E:\DVD_0_Title_02_E2.m2v"
-SEG2vidmode LB
-SEG2a1 "E:\DVD_0_Title_02_E2_1.ac3"
-SEG2a1lang en
-SEG2cellfr "E:\DVD_0_Title_02_E2_Chapters.txt"
-SEG2progfr "E:\DVD_0_Title_02_E2_Chapters.txt"
-SEG2chapfr "E:\DVD_0_Title_02_E2_Chapters.txt"
-SEG3v "E:\DVD_0_Title_03_E3.m2v"
-SEG3vidmode LB
-SEG3a1 "E:\DVD_0_Title_03_E3_1.ac3"
-SEG3a1lang en
-SEG3cellfr "E:\DVD_0_Title_03_E3_Chapters.txt"
-SEG3progfr "E:\DVD_0_Title_03_E3_Chapters.txt"
-SEG3chapfr "E:\DVD_0_Title_03_E3_Chapters.txt"
-SEG4v "E:\DVD_0_Title_04_X1.m2v"
-SEG4vidmode LB
-SEG4a1 "E:\DVD_0_Title_04_X1_1.ac3"
-SEG4a1lang en
-SEG4cellfr "E:\DVD_0_Title_04_X1_Chapters.txt"
-SEG4progfr "E:\DVD_0_Title_04_X1_Chapters.txt"
-SEG4chapfr "E:\DVD_0_Title_04_X1_Chapters.txt"
-SEG5v "E:\DVD_0_MenuPage1.m2v"
-SEG5vidmode LB
-SEG5a1 "E:\DVD_0_Menu.ac3"
-SEG5s1 "E:\DVD_0_Menu.sst"
-SEG5hlmnu "E:\DVD_0_MenuPage1_Buttons.mnu"
-SEG5hlcsm "E:\DVD_0_HighlightScheme.csm
-hcn "E:\DVD_0_BatchMux.hcn"
<2/4/2012 3:12:26 PM>
PROCESS ABORTED.
What about other projects with other source clips? Do you get errors any time or only with this project?
Bye
Hi MrC,
It fails on other computers with other source clips. Log is below. I am running an Nlight version of WindowsXP. Does MuxMan depend on any Windows services? The custom version of Windows I run has many of the services stripped out. Could this be the problem? Thanks for your help.
426_0.log
<2/3/2012 2:05:56 PM>
START PROCESS
PROJECT SETTINGS
DVD Size: 4168/4450 MB (94%)
DVD Label: 426
PREFERENCES
MultiThread: 1
Video Resolution: 0
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
Chapters Interval: 5
DVD Burning Drive: F: LITE-ON DVDRW SHW-160P6S PS0C
Auto Erase DVD RW: 1
Save Log file: 1
Video: C:\AVIs\Ep 4 to 6\E4.avi
Info: DivX 5 - 1771 kbps - 640x364 - DAR 1.758 - 25 fps (CFR) - Progressive - 40:58 minutes - 61472 frames
Audio 1: C:\AVIs\Ep 4 to 6\E4.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 40:58 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\AVIs\Ep 4 to 6\E4.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\AVIs\Ep 4 to 6\E4.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Target Video FileSize: 1115.7 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.HCenc.log
*MAXBITRATE 9000
*BITRATE 3806
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 3:51:51 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.m2v (1116.3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3833 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 40:58 minutes - 61472 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 4:01:36 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.m2v (1116.3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3833 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 40:58 minutes - 73689 frames
<2/3/2012 4:01:39 PM>
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_1.ac3"
<2/3/2012 4:05:32 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_1.ac3 (56.3 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 40:58 minutes (0 ms delay)
Video: C:\AVIs\Ep 4 to 6\E5.avi
Info: DivX 5 - 1881 kbps - 640x364 - DAR 1.758 - 25 fps (CFR) - Progressive - 41:40 minutes - 62524 frames
Audio 1: C:\AVIs\Ep 4 to 6\E5.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 41:40 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\AVIs\Ep 4 to 6\E5.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\AVIs\Ep 4 to 6\E5.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Target Video FileSize: 1134.7 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.HCenc.log
*MAXBITRATE 9000
*BITRATE 3806
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 5:53:16 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.m2v (1135.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3833 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 41:40 minutes - 62524 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 6:01:47 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.m2v (1135.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3833 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 41:40 minutes - 74951 frames
<2/3/2012 6:01:50 PM>
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_1.ac3"
<2/3/2012 6:06:22 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_1.ac3 (57.2 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 41:40 minutes (0 ms delay)
<2/3/2012 6:06:23 PM>
Video: C:\AVIs\Ep 4 to 6\E6.avi
Info: DivX 5 - 2051 kbps - 640x364 - DAR 1.758 - 25 fps (CFR) - Progressive - 47:27 minutes - 71198 frames
Audio 1: C:\AVIs\Ep 4 to 6\E6.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 47:27 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\AVIs\Ep 4 to 6\E6.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\AVIs\Ep 4 to 6\E6.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Target Video FileSize: 1292.2 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.HCenc.log
*MAXBITRATE 9000
*BITRATE 3806
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 8:10:11 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.m2v (1292.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3833 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 47:27 minutes - 71198 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 8:20:04 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.m2v (1292.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3833 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 47:27 minutes - 85351 frames
<2/3/2012 8:20:08 PM>
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_1.ac3"
<2/3/2012 8:24:26 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_1.ac3 (65.2 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 47:27 minutes (0 ms delay)
<2/3/2012 8:24:27 PM>
Video: C:\AVIs\Ep 4 to 6\WA.avi
Info: DivX 5 - 1674 kbps - 640x360 - DAR 1.778 - 25 fps (CFR) - Progressive - 10:28 minutes - 15721 frames
Audio 1: C:\AVIs\Ep 4 to 6\WA.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 10:28 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\AVIs\Ep 4 to 6\WA.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos", FrameRate=25, VFR=false)
Audio = A2DAudioSource("C:\AVIs\Ep 4 to 6\WA.avi", CacheFolder="C:\Documents and Settings\Owner\My Documents\My Videos")
Target Video FileSize: 285.4 MB
HCenc Parameters: -ini "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.HCenc.ini"
HCenc ini file:
*INFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.m2v
*LOGFILE C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.HCenc.log
*MAXBITRATE 9000
*BITRATE 3806
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 8
*MATRIX NOTCH
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2/3/2012 8:50:42 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.m2v (285.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3832 kbps - 720x480 - DAR 1.778 - 25 fps (CFR) - Progressive (TFF) - 10:28 minutes - 15721 frames
DGPulldown Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.m2v" -srcfps 25.000 -destfps 29.97 -inplace -tff
<2/3/2012 8:51:36 PM>
DGPulldown executed on File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.m2v (285.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3832 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 10:28 minutes - 18843 frames
<2/3/2012 8:51:37 PM>
Wavi+Aften Parameters: "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_1.ac3"
<2/3/2012 8:52:52 PM>
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_1.ac3 (14.4 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 10:28 minutes (0 ms delay)
<2/3/2012 8:52:53 PM>
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: Series 5
Max Titles Page: 12
Enable Play All: 0
Force Play All: 0
Background Audio: 1
Max Thumbs Row: 4
HL Frame Format: 1
HL Play Color: 0
Play All Shadow: 2
Arrows Shadow: 0
<2/3/2012 9:00:57 PM>
Created File (Menu Page 1): C:\Documents and Settings\Owner\My Documents\My Videos\426_0_MenuPage1.m2v (25 MB)
Created File: C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Menu.ac3 (1.4 MB)
BatchMux Parameters: -arglist "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_BatchMux.ini"
BatchMux ini file:
-d "C:\Documents and Settings\Owner\My Documents\My Videos\426_0\VIDEO_TS"
-mxp "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_MuxMan.mxp"
-l "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_MuxMan.log"
-prio LOW
-palette "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Palette.txt"
-v "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_1.ac3"
-a1lang en
-cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_Chapters.txt"
-progfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_Chapters.txt"
-chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_01_E4_Chapters.txt"
-SEG2v "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_1.ac3"
-SEG2a1lang en
-SEG2cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_Chapters.txt"
-SEG2progfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_Chapters.txt"
-SEG2chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_02_E5_Chapters.txt"
-SEG3v "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6.m2v"
-SEG3vidmode LB
-SEG3a1 "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_1.ac3"
-SEG3a1lang en
-SEG3cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_Chapters.txt"
-SEG3progfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_Chapters.txt"
-SEG3chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_03_E6_Chapters.txt"
-SEG4v "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA.m2v"
-SEG4vidmode LB
-SEG4a1 "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_1.ac3"
-SEG4a1lang en
-SEG4cellfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_Chapters.txt"
-SEG4progfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_Chapters.txt"
-SEG4chapfr "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Title_04_WA_Chapters.txt"
-SEG5v "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_MenuPage1.m2v"
-SEG5vidmode LB
-SEG5a1 "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Menu.ac3"
-SEG5s1 "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_Menu.sst"
-SEG5hlmnu "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_MenuPage1_Buttons.mnu"
-SEG5hlcsm "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_HighlightScheme.csm
-hcn "C:\Documents and Settings\Owner\My Documents\My Videos\426_0_BatchMux.hcn"
<2/3/2012 9:01:07 PM>
PROCESS ABORTED.
Is there a known issue with some HD sources (1920 x 1080 .Wmv, would be a good example) that causes the encoder (probably talking about QuEnc here -- not sure if this would also appy to HCenc) to slow down to a crawl, causing the job to take many hours to complete ? I've seen some where it ran overnight and was still crawling 8 hours later.
When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
I have no problems with the encoding part of the process. It produces the elementary streams correctly. In fact I can load these elementary streams into DVDstyler, and produce an iso or dvd structure folders with no problems. AVAtoDVD always crashed during the authoring stage. That's why I was wondering if MuxMan is dependent on any Windows services.
What is the "other computers" OS?
Address this question to MPUCoder, author of MuxMan: http://forum.doom9.org/showthread.php?t=157866
BTW, do you have the possibility to upload the clip you are trying to convert?
Bye
MrC, I was using version 4 beta I believe and it worked well. Then, I updated XP with SP3, added a few media players to test them out, came back to it about a year later and AVStoDVD had made all the video into B&W with colored bands in it. I have no idea what happened even after a re-install. Do you?
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Hope someone can answer this. I am using AVStoDVD to convert 1080p or 720p videos to DVD-5 size to put on a standard DVD-R. Is there any benefit to using the 1080p source file over the 720p file? Will the final outcome have a quality difference? Thanks a ton! Love your program MrC.
Hi,
Love AVStoDVD but need some help.
In the log file, what do numbers stand for after "AC3 audio encoder:"?
I've been trying to convert a mkv file. video nicely converted but no audio. but then after reading here, I tried ticking off the "keep AC3/... DVD compliant audio", then got a successful full convertion.
Now, I'm trying others convertions but can't get the audio again...even when keeping all preferences settings as with the successful convertion.
I compared the log files, and all un-successful convertions show "output audio info" with 6Ch instead of 2Ch.
How can I solve that?
Many thanks for help and also (most importantly) for this new software...
V.Last edited by vblanche; 15th Feb 2012 at 04:34.
Thanks for your reply.
the successful log:
the unsuccessful:<14/02/2012 14:07:32>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 4449/4450 MB (100%)
DVD Label: Finding Nemo
DVD Menu: No Menu
Output Folder: D:\AVStoDVD output
Delete Temp Process Files: Yes
Delete Working Files: Yes
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
Video Resolution: 0
AC3 Audio Encoder: 2
DVD Audio Format: 0
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Burning Drive: E: HL-DT-ST DVD-RAM GH22NS30 1.01
Save Log file: 1
Video: D:\moveis\FINDING NEMO.2003.720p.HDTV.DTS-ESIR\Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.mkv
Info: AVC - 5460 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:32:20 hours - 132829 frames
Audio 1: D:\moveis\FINDING NEMO.2003.720p.HDTV.DTS-ESIR\Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.mkv
Info: DTS - 768 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 1:32:20 hours (0 ms delay) - Internal
[MediaInfoLib - v0.7.50]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\moveis\FINDING NEMO.2003.720p.HDTV.DTS-ESIR\Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.mkv", CacheFolder="C:\Users\vincent\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("D:\moveis\FINDING NEMO.2003.720p.HDTV.DTS-ESIR\Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.mkv", CacheFolder="C:\Users\vincent\AppData\Local\Temp")
Video = Video.Spline64Resize(720,576)
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 4053 MB
HCenc Parameters: -ini "C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_1.avs
*AVSRELOAD
*OUTFILE C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.m2v
*LOGFILE C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 6137
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<14/02/2012 14:49:45>
A2DVideoSource: DirectShowSource
Created File: C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.m2v (4035.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6170 kbps - 720x576 - DAR 1.778 - 23.976 fps (CFR) - Progressive (TFF) - 1:32:06 hours - 132508 frames
DGPulldown Parameters: "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<14/02/2012 14:55:03>
DGPulldown executed on File: C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.m2v (4035.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6164 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:32:12 hours - 132773 frames
<14/02/2012 14:55:04>
QuEnc (AC3) Parameters: -i "C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_1.avs" -o "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_1.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec ac3 -audiobitrate 448 -auto -close
<14/02/2012 15:05:26>
Created File: C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_1.ac3 (295.5 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:32:12 hours (0 ms delay)
BatchMux Parameters: -arglist "C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_BatchMux.ini"
BatchMux ini file:
-d "D:\AVStoDVD output\Finding Nemo_2\VIDEO_TS"
-mxp "C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_MuxMan.mxp"
-l "C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\vincent\AppData\Local\Temp\Finding Nemo_2_Palette.txt"
-v "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR.m2v"
-vidmode LB
-a1 "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_1.ac3"
-a1lang en
-cellfr "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_Chapters.txt"
-progfr "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_Chapters.txt"
-chapfr "C:\Users\vincent\Videos\Finding Nemo_2_Finding.Nemo.2003.720p.HDTV.DTS.x264-ESiR_Chapters.txt"
<14/02/2012 15:11:15>
CHECK DVD SIZE
DVD Folder (actual) Size: 4414.6 MB
vs Estimated Size: 4449 MB -> 0.8% undersize
vs Assets Size: 4331.4 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: D:\AVStoDVD output\Finding Nemo_2 (4414.6 MB)
<14/02/2012 15:11:19>
Log file created by AVStoDVD Release 2.4.2
<14/02/2012 20:49:59>
START PROCESS
PROJECT SETTINGS
DVD Size: 4450/4450 MB (100%)
DVD Label: BOLT
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
Video Resolution: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
Save Log file: 1
Video: D:\moveis\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv
Info: AVC - 8207 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:36:22 hours - 138630 frames
Audio 1: D:\moveis\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv
Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 1:36:22 hours (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\moveis\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv", CacheFolder="C:\Users\vincent\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("D:\moveis\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv", CacheFolder="C:\Users\vincent\AppData\Local\Temp")
# Workaround to fix QuEnc multichannel audio mapping bug
Audio = Audio.GetChannel(1,3,2,5,6,4)
Target Video FileSize: 4047.4 MB
HCenc Parameters: -ini "C:\Users\vincent\AppData\Local\Temp\BOLT_5_19 20-bolt.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\vincent\AppData\Local\Temp\BOLT_5_1920-bolt_1.avs
*AVSRELOAD
*OUTFILE C:\Users\vincent\Videos\BOLT_5_1920-bolt.m2v
*LOGFILE C:\Users\vincent\AppData\Local\Temp\BOLT_5_1920-bolt.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 5872
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<14/02/2012 22:18:30>
Created File: C:\Users\vincent\Videos\BOLT_5_1920-bolt.m2v (4001.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5852 kbps - 720x576 - DAR 1.778 - 23.976 fps (CFR) - Progressive (TFF) - 1:36:16 hours - 138488 frames
DGPulldown Parameters: "C:\Users\vincent\Videos\BOLT_5_1920-bolt.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<14/02/2012 22:25:03>
DGPulldown executed on File: C:\Users\vincent\Videos\BOLT_5_1920-bolt.m2v (4001.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5847 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:36:21 hours - 138765 frames
<14/02/2012 22:25:05>
Wavi+Aften Parameters: "C:\Users\vincent\AppData\Local\Temp\BOLT_5_19 20-bolt_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\vincent\Videos\BOLT_5_1920-bolt_1.ac3"
<14/02/2012 22:29:48>
Created File: C:\Users\vincent\Videos\BOLT_5_1920-bolt_1.ac3 (308.8 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:36:21 hours (0 ms delay)
<14/02/2012 22:29:49>
BatchMux Parameters: -arglist "C:\Users\vincent\AppData\Local\Temp\BOLT_5_BatchM ux.ini"
BatchMux ini file:
-d "D:\AVStoDVD output\BOLT_5\VIDEO_TS"
-mxp "C:\Users\vincent\AppData\Local\Temp\BOLT_5_MuxMan .mxp"
-l "C:\Users\vincent\AppData\Local\Temp\BOLT_5_MuxMan .log"
-prio LOW
-palette "C:\Users\vincent\AppData\Local\Temp\BOLT_5_Palett e.txt"
-v "C:\Users\vincent\Videos\BOLT_5_1920-bolt.m2v"
-vidmode LB
-a1 "C:\Users\vincent\Videos\BOLT_5_1920-bolt_1.ac3"
-a1lang en
-cellfr "C:\Users\vincent\Videos\BOLT_5_1920-bolt_Chapters.txt"
-progfr "C:\Users\vincent\Videos\BOLT_5_1920-bolt_Chapters.txt"
-chapfr "C:\Users\vincent\Videos\BOLT_5_1920-bolt_Chapters.txt"
<14/02/2012 22:36:02>
CHECK DVD SIZE
DVD Folder (actual) Size: 4394.5 MB
vs Estimated Size: 4450 MB -> 1.2% undersize
vs Assets Size: 4310.2 MB -> OK
Created Folder: D:\AVStoDVD output\BOLT_5 (4394.5 MB)
<14/02/2012 22:36:19>
In both projects there are conflicts between the AC3 audio encoder selected and the AviSynth script produced, probably because you have changed the AC3 encoder AFTER adding the title.
Let's make some order.
0. Reset your project OR restart AVStoDVD
1. Go to 'Preferences'/'Audio'
2. Toggle off 'Keep DVD Compliant Audio'
3. Select 'Wavi+Aften'
4. Add the title to be converted
If you want to use another AC3 encoder, FIRST select the new encoder (i.e. QuEnc), THEN add the title.
One of AVStoDVD main rule is that Preferences have to be set up before to start any project. In fact a message popup warns you when you make Preferences changes with a project already initialized.
Bye
Any response to my post #728, above ?
Thanks again.
So, i've done what you suggested, here is the result:
I'm still getting an audio output in 6Ch...confused now.<16/02/2012 07:39:38>
START PROCESS
PROJECT SETTINGS
DVD Label: bolt
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
Video Resolution: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
Save Log file: 1
Video: D:\Movies\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv
Audio 1: D:\Movies\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\Movies\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv", CacheFolder="C:\Users\vincent\AppData\Local\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("D:\Movies\Bolt.1080p.BluRay.x264-1920\1920-bolt.mkv", CacheFolder="C:\Users\vincent\AppData\Local\Temp")
HCenc Parameters: -ini "C:\Users\vincent\AppData\Local\Temp\bolt_2_19 20-bolt.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\vincent\AppData\Local\Temp\bolt_2_1920-bolt_1.avs
*AVSRELOAD
*OUTFILE C:\Users\vincent\Videos\bolt_2_1920-bolt.m2v
*LOGFILE C:\Users\vincent\AppData\Local\Temp\bolt_2_1920-bolt.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 5872
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<16/02/2012 09:10:37>
Created File: C:\Users\vincent\Videos\bolt_2_1920-bolt.m2v (4001.4 MB)
DGPulldown Parameters: "C:\Users\vincent\Videos\bolt_2_1920-bolt.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
<16/02/2012 09:17:37>
DGPulldown executed on File: C:\Users\vincent\Videos\bolt_2_1920-bolt.m2v (4001.4 MB)
<16/02/2012 09:17:38>
Wavi+Aften Parameters: "C:\Users\vincent\AppData\Local\Temp\bolt_2_19 20-bolt_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\vincent\Videos\bolt_2_1920-bolt_1.ac3"
<16/02/2012 09:20:41>
Created File: C:\Users\vincent\Videos\bolt_2_1920-bolt_1.ac3 (308.8 MB)
<16/02/2012 09:20:42>
BatchMux Parameters: -arglist "C:\Users\vincent\AppData\Local\Temp\bolt_2_BatchM ux.ini"
BatchMux ini file:
-d "D:\AVStoDVD output\bolt_2\VIDEO_TS"
-mxp "C:\Users\vincent\AppData\Local\Temp\bolt_2_MuxMan .mxp"
-l "C:\Users\vincent\AppData\Local\Temp\bolt_2_MuxMan .log"
-prio LOW
-palette "C:\Users\vincent\AppData\Local\Temp\bolt_2_Palett e.txt"
-v "C:\Users\vincent\Videos\bolt_2_1920-bolt.m2v"
-vidmode LB
-a1 "C:\Users\vincent\Videos\bolt_2_1920-bolt_1.ac3"
-a1lang en
-cellfr "C:\Users\vincent\Videos\bolt_2_1920-bolt_Chapters.txt"
-progfr "C:\Users\vincent\Videos\bolt_2_1920-bolt_Chapters.txt"
-chapfr "C:\Users\vincent\Videos\bolt_2_1920-bolt_Chapters.txt"
<16/02/2012 09:25:35>
CHECK DVD SIZE
Created Folder: D:\AVStoDVD output\bolt_2 (4394.5 MB)
<16/02/2012 09:25:36>
thanks
vince
@vblanche
Input audio is 6ch, output audio is 6ch. What's wrong with it?
From the log file everything is OK. What about the resulting DVD?
Bye
Well, I thought I needed 2Ch for DVD, but I was wrong:
However, with the successful converted file, 6Ch has been converted in 2Ch, and VLC can play it. VLC won't play the audio of all convertion attempts that give me a 6Ch audio output, so that's maybe my problem, is it?- PCM: 48 kHz or 96 kHz sampling rate, 16 bit or 24 bit Linear PCM, 2 to 6 channels, up to 6,144 kbit/s. N.B. 16-bit 48 kHz 8 channel PCM is allowed by the DVD-Video specification but is not well-supported by authoring applications or players.
- AC-3: 48 kHz sampling rate, 1 to 5.1 (6) channels, up to 448 kbit/s
- DTS: 48 kHz or 96 kHz sampling rate, 2 to 6.1 channels, Half Rate (768 kbit/s) or Full Rate (1,536 kbit/s)
- MP2: 48 kHz sampling rate, 1 to 7.1 channels, up to 912 kbit/s
I haven't tried burning on disk and read with a standalone DVD player, but I assume that VLC is reading DVD folder as if it was a DVD?
update: maybe I'm stupid? (don't answer that
)...I don't have a 6Ch audio output on my pc, but shouldn't VLC play the audio anyway? how could I convert the audio of the converted DVD into 2Ch?
update2: I'm listening with stereo headphones, therefore I guess I will never hear the 6ch audio...
still how did AVStoDVD converted into 2Ch once and not anymore?Last edited by vblanche; 16th Feb 2012 at 07:45. Reason: well, guess I'm trying to understand...arrrh, these newbies
Not known by me.
Long encoding may be caused by poor codecs, CPU already loaded by other apps, avisynth script with many filters calls.
Bye
I don't use VLC, so I don't know how it downmix 6ch to 2ch. Burn the DVD (RW, I suggest) and play it on your standalone player and use your ears with your 5+1 system to check if everything is OK.
Moreover, as I told you before, be careful how your directshow AC3 decoder mixer is setup. See FAQ/Audio/Q4.1 for more details.
Bye
ok, thanks. I indeed need to buy some DVD+RW to do some test.
In the mean time, I don't understand why from the same source, I got 2 conversions: one into 6CH and one into 2CH...that's weird, isn't it?
also, the source file (DTS, 6CH) is read w/o problem by VLC, and I have other DVDs with 6CH audio that VLC also reads w/o prob. So, I assume something went wrong during the conversion.
Finally, I had AC3Filter installed as I thought I needed it, but then I un-installed it...maybe it's a problem, what do you think?
Many thanks for your help.
VinceLast edited by vblanche; 17th Feb 2012 at 03:49. Reason: additional info
Hi, can I ask what does the line 'A2DAudioSource: DirectShowSource' mean/do in this group? thanks
If you have already installed another AC3 directshow decoder (i.e. ffdshow), then you don't need AC3Filter, otherwise you do.
Bye
A2DAudioSource is part of A2DSource.avsi, an AviSynth script I have developed some years ago. For more details see Help/How to use it/Preferences Window/AviSynth/AviSynth Source Filter.
If you like technobubbles: http://forum.doom9.org/showthread.php?p=1215535
Bye
Under Edit Title – Avisynth –tab is an ”Amplify Audio” –option. It opens a window which says
Insert Audio Amplify factor (in decibel).
Values > 1 mean volume gain.
Values < 1 mean volume decrease.
However, if I try to reduce the volume by giving a value -4, I get the warning:
“Invalid value entered”.
Am I doing something wrong, or is this a bug?
(AVStoDVD version is 2.4.2.)
JuMe
Yes, that's a bug. With current release you can do only volume increase. If you want to decrease volume, you have to manually edit the AviSynth script.
Next release will have the fix. Thanks for the report.
Bye
First of all I want to say a big THANK YOU to Mr_C for creating AVStoDVD! I very much appreciate it.
Second, I don't know if my question has been asked before as there are 25 pages of responses on this thread, so I will just go ahead and ask.
I used AVStoDVD to make a great many DVDs but lately I have been getting an error when I go to play them in a dvd player saying "No Disc". It is only on one project that I have been working on a long time now so I imagine it has to do with one of the files.
I have 15 WMV files that end up each as their own title. I also am using a jpg for the background and am doing quite a bit of adjustments to font color, outline, and Bold from what the defaults are. One thing I noticed is that if I take all of the default properties off the font (bold, Outline, Italics, etc) then go to another title's text, then return to the text I altered previously it puts the Bold button back as active.
Anyway, all of this used to be ok and burned fine til I started making small changes to the wmv files, and placing the new versions into the folder where AVStoDVD pulls them from.
Any help on this would be much appreciated as I have probably thrown 10 dvd's away now.
P.S. - I can take the "No Disc" dvd and put it into my computer and it will play fine.
P.S.S. - I have also noticed that sometimes the dvd player will recognize the dvd as such, but takes a long time to spin and spool before it can determine it is indeed a dvd...
Thank you!
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 675Last Post: 6th May 2012, 01:04 -
TEncoder - Multithreaded GUI for FFMpeg and Mencoder (Support thread)
By ozok in forum Video ConversionReplies: 28Last Post: 22nd Apr 2012, 20:12 -
Hybrid [x264/XViD - MKV/MP4] Converter Support Thread
By Bonie81 in forum Video ConversionReplies: 0Last Post: 5th Nov 2011, 19:58 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37 -
Start product support thread?
By midders in forum FeedbackReplies: 2Last Post: 4th Aug 2009, 14:15
