Greetings,
I have recently decided to buy my own camcorder as borrowing from friends has been unreliable. The initial purpose is to film an annual snowboarding trip with friends however I would like the ability to dabble in making some short films. My budget is quite limited and I would like to get something decent for under $600. I have read some reviews of some particular camcorders and have focused my attention on (Panasonic SDR-H250 or GS-230), some of the reviews of these cams said the video quality was 'Poor' but I don't know what the reviewers definition of 'Poor' is. As my budget is quite low I do not expect my movies will be of the highest standard anyway so I basically just want the best I can get for my money. I am also unsure as to whether I would be better off getting the SDR-250 over the GS-230 for the HDD vs MiniDV argument.
While the 2 camcorders I mentioned are readily available where I am I am certainly open to getting a different camcorder on solid recommendation. I am also happy to here any comparisons between the models I have noted.
I have heard that low light can be a real problem for these Panasonics so suggestions around cameras that perform better in low light would be appreciated.
Thanks in advance for your responses.
Cheers
ChesneX
Thread: Which Camcorder under $600
The Panasonic PV-GS320 can be had for $400 or less online. It's a great 3CCD budget camera. The major drawback is it doesn't have a mic input. They are susceptible to low light just like any consumer model. In proper lighting the picture is fantastic. You need to learn proper manual controls to get the most out of your shot.
For your budget you could get that camera with a bunch of accessories.
you can probably get a high definition cam for this amount
just be aware you'll probably have to build a new computer to handle the editingAuthor, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Canon Digic II DV cameras, Z-series.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
I did look at that model but was concerned about the lack of Mic imput with particualr reference to the Short Film making. Thats why I leaned towards the GS-230, do you think there is much diference between the two quality wise?Originally Posted by stantheman1976
Cheers
Chesnex
It appears the Digic's I found are only single CCD do you think the Panasonics would be better being 3CCD?Originally Posted by lordsmurf
Cheers
ChesneX
I prefer the Sony HC96, its better in lowlight than the pana GS320.
www.hc96.de -> All about the Sony DCR-HC96 and Camcorder accessories.
TV Wonder 600 and TV Wonder HD 600, is there any real difference?
By jedi55 in forum CapturingReplies: 3Last Post: 20th Mar 2011, 21:53 -
WHICH LAPTOP for around $600
By blinky88 in forum ComputerReplies: 16Last Post: 18th Mar 2011, 03:23 -
Newb needs $400 - $600 camcorder solution...
By Shortbus64 in forum Camcorders (DV/HDV/AVCHD)Replies: 10Last Post: 2nd Aug 2009, 17:31 -
Best HD Flash Based Camcorder for $600
By Mike82 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 9th Jun 2009, 09:59 -
Biostek XS-600 help
By binkx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Oct 2008, 08:46
