A necessary declaration. I did a search on forums and I intend to do it again. Some solutions were tried. If I failed to find some already-discussed topic -- I'm really sorry.
There is a batch of .mkv files, which i intend to turn into a batch of dvd's. Unfortunately, these files were coded in VFR.
The first attempt by means of avi_tc brought no result. Every time avi_tc failed with following error message
I tried both mkv2vfr and MkvExtractGui to get timecode. Tried to convert timecodes between formats. No result besides this message.CLI Output:
tc2cfr v1.5 by tritical.
Descernable number of framrates: 340 (min = 0.352589 fps).
v1 timecode file type detected.
Invalid frame range detected in v1 timecode file (0-1535).
I faced this problem before, failed to solve it, and reverted to Avisynth.
I made a following script
Last time I needed to deal with VFR it worked.DirectShowSource("filename.mkv", fps=25, convertfps=true)
But this time no application plays file with it -- VirtualDub says that "no video stream found" and MediaPlayerClassic starts to play sound with no video.
File is 100% working. Both playing and extracting of video go on normally. Tried to load it into Windows Media Player -- except funny attempt to play two soundtrack at once -- it is played.
SUPER says following about file's video part
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
So -- does anyone have any insights on any way to get these files into obedience?
Thanks beforehand!!
Read the ffmpegsource thread http://forum.doom9.org/showthread.php?t=127037
Supposed to work pretty well with VFR sources. Never tried it on MKV files, but other have. -
AviSynth is the right way to do it. It is also necessary to make DirectShow filters work properly:
a) provide playback of that file type;
b) make them loaded at loading the script into VDub and your encoder
I had recently a similar problem with one mkv file and one particular rm file. Playback worked in MPC (FFDShow+Haali Media Splitter and RealAlternative installed) and files opened in Vdub but not in AVSP and CCE. After I installed latest FFDShow, it started to pop up a window offering to load itself at opening the script in either application and this solved the problem. The convertfps parameter in DirectShowSource will take care of VFR. -
Thanks for your help guys!
A night of frantic experiments resulted in... third solution.
If troublesome MKV is re-muxed without sound or subtitles -- it is played fine. -
(I'm using AviSynth v2.55, VirtualDubMod, and CCCP)
I made an error about which version of Synth I was using. Now corrected.where bananas go to church...
...a monkey will be their preacher -
http://nyaochi.sakura.ne.jp/xoops/modules/mydownloads/index.php
It seems that a post on doom9 (http://forum.doom9.org/showthread.php?s=&threadid=90938) had my answer.where bananas go to church...
Originally Posted by sweetfreek
Please download latest stable Avisynth 2.5.7 (eventually unstable 2.5.8 ).
What mobile phones uses VFR (or CFR) for recorded video clips?
By Gew in forum Portable VideoReplies: 0Last Post: 27th Jan 2012, 11:49 -
VFR -> CFR in VirtualDub
By KeyMs92 in forum EditingReplies: 19Last Post: 7th Oct 2011, 18:41 -
vfr to cfr convertion
By mathmax in forum Newbie / General discussionsReplies: 11Last Post: 22nd Apr 2011, 08:11 -
easy way to convert VFR >>> CFR ?
By Force88 in forum Video ConversionReplies: 8Last Post: 16th Mar 2009, 08:41 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41
