    Ok I reformatted my Hp Pavilion 2610 to xp home edition. Now my only problem is the drivers. The sound driver is that altec lansing audio. I have no idea where to get the drivers. And any other drivers for other things for the laptop. The problem is that hp homesite does not have many drivers for them...so I am at a loss.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    From what I can tell, that laptop uses a 'Conexant High-Definition Audio Driver'. Searching around on the net, I found this one for XP that may work:
    http://h10025.www1.hp.com/ewfrf/wc/g...tem=ob-40619-1
    Since that laptop was apparently configured for Vista, you may have to dig a little to find all the drivers. Get the name of the drivers that are listed for Vista on the HP site and try a Google search using the that exact name. That's how I found that one. HP will be no help, but they may have all the drivers you need, just buried among all the laptop driver files. Their other suggestion was to check Windows update and see if drivers are available through that.
    Video card drivers can probably be downloaded from Nvidia, LAN drivers from who ever made the LAN if you can't find them with a search.
    I hope you kept your Vista backup discs. This may not be a easy OS changeover.
    If that's anything like my HP laptop, Altec Lansing is just the speaker maker, not the chipset name.
    If you still have problems, try the folks at the Pavilion laptop forum here:
    http://forums1.itrc.hp.com/service/f...categoryId=411
    I've used the associated Pavilion desktop forum before and the people there are very knowledgeable about which drivers go with which models and they get a lot of questions about XP downgrades.
    it's a real drag....it still doesn't make a sound, perhaps its cus that one file didn't copy over during the reformatting
    ok, i tried again and the sound still doesn't work....
  6. Have you researched your exact model, found out exactly what sound hardware you have, and then Google searched for the associated XP driver? Much of this was done for you.
    Hint - Altec Lansing ain't it.
    A clearer explanation of exactly what you have tried and exactly how it failed would be more useful.
  1. display driver problem
    By ray316 in forum Computer
    Last Post: 14th Jan 2006, 08:09
  2. device driver problem
    Last Post: 14th Dec 2005, 20:20
  3. Replies: 1
    Last Post: 17th Oct 2004, 08:57
  4. driver problem
    By beavereater in forum Computer
    Last Post: 20th May 2004, 12:09
  5. ATI driver problem
    By in forum Capturing
    Last Post: 7th Sep 2002, 19:44
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
