VideoHelp.com Forum
  1. Will I get better picture quality from my standard DVD player by connecting to my new HDTV using an S Video cable vrs. RCA cable?
    Yes
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    If you can connect the dvd player with HD component cable(s) use them instead. S video is not as good as component.
  4. Member Krispy Kritter's Avatar
    Quality...from worst to best: composite (yellow RCA), coax, S-Video, component (Red/Green/Blue RCA), DVI/HDMI
    Google is your Friend
    To save a bit of time here, perhaps you could tell us a few things about your HDTV:
    1) What type it is (Plasma, LCD, Laser, etc)...
    2) What kind of connectors are present on the back...
    3) What kind of connectors are available on your DVD player...
    By standard, I assume you mean it is a standard-definition player, so component is probably the best way to go. S-video is an acceptable compromise, but a lot of DVD players will only output a "progressive" signal through component. So if you can use component, then do so.
    Do not bother with composite (single yellow cable). You are wasting your superior TV's capabilities if you do so.
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
  6. Use Component and progressive scan. If the player doesn't have progressive, get one that does. For best picture quality, get a decent player not a bottom of the line cheapie.
  7. Thanks to all for the very helpful info. The 32" LCD HDTV, 720p, is a Sony Bravia. I connected the DVD player via component cables and the picture is great!
  8. Turn on progressive scan if the player has it. Almost all players manufactered in the last few years have progressive.
  1. How would I connect my standard cable box to my HD LCD monitor?
    By Jadedrain_06 in forum Video Conversion
    Last Post: 27th Nov 2011, 12:00
  2. Replies: 3
    Last Post: 9th Oct 2009, 13:45
  3. Is This The Right Cable To Connect My Pc To HDTV?
    By superstar in forum DVB / HDTV
    Last Post: 10th May 2008, 18:53
  4. Replies: 0
    Last Post: 23rd Oct 2007, 22:56
  5. Standard cable on hdtv...
    By bla4free in forum Newbie / General discussions
    Last Post: 23rd Jun 2007, 22:35
