VideoHelp.com Forum
    **** The Problem - Laymans description ****
    Having spent 600 Euros on a new Sony DCR-SR32E HDD camera I have found that I
    am unable to edit any footage using commercially available editors.
    Mpg's created by the Sony DCR-SR32E cause all video editors to crash. However,
    the MPgs play in several video players without any problems. Mpgs not originating
    from the Sony camera are fine, can be edited and played without a problem.
    Video editors I have tried to date:
    Pinnacle Studio Version 8.0
    Adobe Premier 6.0
    Windows Movie Maker 5.1
    The Mpgs reside in a folder on my PC Hard Drive, copied from the camera.
    Both Pinnacle and Adobe Premier crashed outright on importing any Sony mpg. The apps just freeze,
    display an error message, or simply close themselves. Windows Movie Maker attempts to load
    the Mpg & manages to create a thumbnail of the scene. But if the thumbnail is dragged onto
    the timeline - a high pitched whirr is emmitted from the PC unit (I'm not making this up)
    and the app crashes. Task manager is necessary to kill the app after this.
    Sometimes WMM will open a file, display an error, but stay open. The video can be previewed,
    but this is not true of every file. Only some !
    **** Technical Details ****
    Camera: Sony DCR-SR32E
    My PC: AMD ATHLON XP 2400+
    VIA CHIPSET.
    512Mb RAM
    MPEG: MPEG2
    Average file size 21Mb
    Adobe Error Message:
    Standard "I have encountered an error and will shut down" dialog
    Windows Movie Maker Error Message:
    I have used G-Spot V2.7 to analyze the Sony MPG files, and it reports:
    ---- Video ----------
    width 720
    Height 576
    Bit Rate 9100
    Frame 25fps
    ---- Audio ----------
    Bit Rate 256
    Channels 6
    Sample Rate 48Khz
    Sample Size 0
    "Codecs are Installed"
    ... and a lot more information that means nothing to me!
    The way I see it - it has to be a specific attribute of these Sony MPG files. As other MPGs can be
    edited no probs. I have downloaded & installed XP Codec Pack 2.2.0 to see if it helped, but no change.
    Help ! All suggestions will be read with unblinking eyes !
    if the error screen cap is not visible the text reads "<filename> could not be imported. An interface has too many methods to fire events from"
  3. Member Soopafresh's Avatar
    By downloading Quicktime Alternative v1.81 http://www.afterdawn.com/software/vi...tive.cfm/v1_81 and MpegStreamClip
    http://www.alfanet.it/squared5/MPEG_...clip_1.2b2.zip
    You can save your files (without re-encoding) to plain old mpeg2 format. Try the resulting file with your editor
    The best app by far to "fix" your file is Videoredo , and while it has a 15 day eval period, it's $50 to buy. Great app, though. One of the few video processing apps that doesn't have a freeware equivalent.
  4. Member lenti_75's Avatar
    usually there is a problem with camera hdd mpeg.
    don't you have a sony software for those files?
    try canopus mpegcraft, see if it work
    Thanks for the replies so far. Very limited software came with the camera - nothing that can edit / add titles / add music etc.
  1. Sony Vegas 11 Rendering Crash
    By colamics in forum Editing
    Last Post: 4th Feb 2012, 11:40
  2. Sony DVD architect 4.0 crash?
    By chronic777 in forum Authoring (DVD)
    Last Post: 30th Dec 2011, 02:54
  3. Replies: 1
    Last Post: 22nd Jan 2009, 10:36
  4. Replies: 6
    Last Post: 9th Oct 2008, 12:38
  5. Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
    By maxtrack in forum Newbie / General discussions
    Last Post: 11th Sep 2007, 00:38
