VideoHelp.com Forum
    Hi everyone,
    I'm trying to burn some old vhs tapes to dvd. I'm using dvd-ram discs to record the tapes, then copy the file to my Hard Drive. I can change the file extension to mpg and it plays fine.
    What I need is a simple program that will allow me to cut off the dead space at the beginning and end, and then burn to dvd-r.
    Menus, thumbnails ect. would be nice although for what I'm planning they really aren't necessary.
    Thanks for any Recommendations,
    Roy
  2. Member Forum Troll's Avatar
    Simple way would be to edit in VideoRedo, then author with TSUNAMI MPEG DVD Author Pro, then burn with Nero or IMGBurn.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Member AlanHK's Avatar
    MPEGVCR is a very good, but not free, MPEG editor.
    You can use it to cut and paste, then demux and author.
    Simple, no menus, one title, authoring, try ReJig.
    Menus, multiple titles, etc, etc, try GuiForDVDAuthor.
    -- both free.
  4. Man of Steel freebird73717's Avatar
    While I haven't tried it a freeware alternative to mpegvcr and videoredo is mpeg2cut2.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
  5. The root of all evil träskmannen's Avatar
    I use ProjectX to demux the VOBs into elementary streams and Cuttermaran to cut them. Both are freeware and there are guides here on this site about how to use them (it is quite easy). Then use any authoring program to get a complete DVD again, I prefer GUI for DVDAuthor if I want to make a menu and IFOEdit or MuxMan if I don't.
    Edit: I forgot about DVDShrink. You are not quite clear in your description of your method but I think you use a DVD recorder, is that correct? If that is the case you can use the re-author mode in DVDShrink to cut the beginning and the end as you want.
    In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
  1. Need Software Recommendation
    By JFolk in forum Newbie / General discussions
    Last Post: 11th Jun 2010, 08:23
  2. Software recommendation
    By pcfitness in forum Authoring (DVD)
    Last Post: 2nd Nov 2008, 21:13
  3. Software recommendation
    By Haopengyou in forum Newbie / General discussions
    Last Post: 8th Jan 2008, 07:28
  4. Software recommendation?
    By zeno in forum Authoring (DVD)
    Last Post: 28th Dec 2007, 11:48
  5. Software recommendation
    By statman24 in forum Newbie / General discussions
    Last Post: 13th Sep 2007, 11:50
