    Although I have instaled many Divx or Xvid codecs(5.0, 6.0, 6.5 ext...) on my laptop (HP nc6220) but i can see it in the codec tab of divx, the codec of AVI files after converted is alway 4.0(Divx).
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You can use a program like DXMan or Codec Sniper to check your codecs and remove any duplicates or damaged ones. Your program may be using one of the older versions instead of the newer ones you installed.
    And welcome to our forums.
