  1. hey guys, what is the easiest method to add short clips on divx
    basically I want to add like 2 or 3 second credit etc2 on my divx
    so before the actual movie play, I want to add this short clips first
    and I want the format still divx, not for DVD etc2
    I will need to put those intro to quite lot of divx
    and because I will outsource this task to few people..so I need easiest method as possible
    help me guys
    Apr 2004
    Miskatonic U
    AVIDemux. However the intro clip must have the same resolution and framerate as the Divx clip it is being joined to, and should have the same basic audio as well (same compression format, same sample rate, and same bitrate if CBR)
    Read my blog here.
  3. well.. what happend if they are not the same ?
    because I will use the same intro for lot of divx
    I kinda guess it may and maynot the same
    there will be no sound on the intro clip
    and as long they play and we can see the text on those clip
    thats more than enough.
    it don't have to be smooth and perfect
    can we force them to join even if they different in compression sample rate etc2 ?
    Apr 2004
    Miskatonic U
    You can't join them if the resolution is different - period.
    If you don't have sound, the audio of the original clip will be shifted down to start at the beginning, throwing the whole thing out sync.
    If you want to try and join non-matching clips you will have to use something like Vegas, and re-encode the entire clip.
    If you want a simple joining solution, everything has to match up.
    Read my blog here.
