  1. Hi, I have tried to convert MPEG file to DivX forma, but while importing using Virtual Dub it has given error as "MPEG Import Filter: invalid pack at position 11651: marker bit not set; possibly MPEG-2 stream" so somewhere I found that
    Virtualdub-MPEG2 should be used so again I tried with that now this tool has given error as "MPEG Import Filter: no video stream!". I don't understand what is problem and how should I solve this?
    Update:
    Uploading screenshot from GSPOT, also one more information this MPEG file has been produced by VCDGear from .dat file.
    Try repair it with VIdeoRedo using the quickstream fix or run it through pvastrumento or remux it with the old tmpgenc under file->mpeg tools. Then try convert it.
    And I guess it work fine to play the mpeg file?
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Open the file in g-spot, then post a screenshot of the results.
    Read my blog here.
