i'm korean drama fans.. I'd download few series but what bother me much is how two video with equal quality and resolution (video width,length) but they have different size of file... for example 250mb with 350mb or 350 mb with 700mb. How the conversion take place since the quality is equal for both sizes.......
File size depends only on bit rate. Bit rate is independent of frame size although higher bit rates usually result in higher picture quality for a given frame size.Originally Posted by mai_hnf
Compression is also affected by the amount of motion in the video. Still shots obviously would compress the best. At the same quality setting a car chase would use a higher bit rate.
They can differ also in duration (time).
Assuming the files are generated from the same source andHow the conversion take place since the quality is equal for both sizes.......
converted with the same program/codec, the respective ways
in which they are encoded make the difference.
Different configuration parameters may lead to the same
visual quality but at different file sizes; regarding DivX/XviD specifically,
multi-pass encoding may significantly reduce
file size without any apparent loss of quality.
best quality smallest size
By Reckitt in forum Video ConversionReplies: 2Last Post: 27th Feb 2011, 08:39 -
WMV files equal to DVD quality
By uniks in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 10:16 -
mpg-2 to ??? size and quality
By l4l4u in forum Video ConversionReplies: 4Last Post: 6th Nov 2009, 15:43 -
[help] small size good quality
By las7h0p3 in forum Video ConversionReplies: 1Last Post: 6th Nov 2008, 08:27 -
Is one of these capture methods better for quality than the other or equal?
By twolf13 in forum CapturingReplies: 3Last Post: 20th May 2008, 10:12
