Hi all,
How do i burn a SVCD onto a DVD using Nero Burning ROM and make the SVCD play on both my PC and a standalone player?
Results 1 to 10 of 10
Thread: How to burn a SVCD onto a DVD?
You can't, a real SVCD can only be burned on a CD. You can burn the SVCD on a DVD in data mode but it wont work that well on dvd players. Instead reconvert to a DVD with svcd2dvdmpg, svcd2dvd or dvd-lab.
1) Get an svcd-capable SAP ^_^
or
2) extract the mpeg from the svcd, demux, remux with a
"non-standard VCD" file header, create a non-standard VCD.
You could do it with Hardware, If you have a DVD recorder & a DVD player that plays SVCD. Than you can edited it on the computer if necessary...
IFOEdit can author a DVD with non-standard resolutions like 480x480. I've done it myself. You have to demux the SVCD file and re-encode the audio to DVD standard LPCM or AC3 first, but you don't have to resize or re-encode the 480x480 4:3 MPEG video file. Note that the finished DVD may not play on all players, but the one I did this for works fine on my players.
svcd2dvdmpg, svcd2dvd and dvd-lab will also make a 480x480/576 "xDVD", no video conversion.
Hey, I do have a SVCD player. I wanted it on a DVD because so i can put more folders onto it. One of the folders plays fine in SVCD but the second folder doesn't play. I know one of my family member and he does it with Divx but i don't have a Divx player. How can i get all my folders to play?
An SVCD has a very specific file structure (as does a DVD). It's not like a computer data disc, where you have an ordinary hierarchical file structure and can simply add files at will. You have to author a multi-chapter (multi-title) SVCD to do what you propose. You'll need a proper authoring tool (like VCD Builder on the Mac) to assemble all the bits and pieces together properly.
I have an article on how to do this with DVDLab
Cheers, Jim
My DVDLab Guides
90% of DVD players support playback of DVDs authored from SVCD/DVB resolution files, that is statistics collected by Womble. DVDLab and MPEG Video Wizard DVD (Womble) support such an authoring without any hack the rest applications want (patching MPEG headers with DVDPatcher to fake resolution). The only thing that should be actually changed is audio sample rate (44.1=>48kHz), some authoring applications do it internally.
A good old article for manually doing it (useful for general understanding the process) is here:
http://www.doom9.org/index.html?/mpg/svcd2dvdr.htm
There are also one-click applications like the mentioned svcd2dvdmpg (free) for MPEG file preparation and svcd2dvd (commercial) for full DVD creating.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 20:34 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
Freeware app to burn SVCD's?
By louv68 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th Jul 2007, 14:28 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 05:07
