I've used this manuel:
http://forum.videohelp.com/topic275603.html
After all done, i want my subtitle to be shown automaticly when playing the movie,
Is there an easy way to do that?
BTW, i've heard this "force subtitle" options makes problems sometimes,
any ideas about that?
In Re-Author Mode, DVDShrink can do it quite easily. http://www.dvdshrink.info/forcing_subs.php
-The Mang
Here is a way to do it using IFOEdit:
http://forum.doom9.org/showthread.php?s=&threadid=45440
I can confirm that this method works. However, some DVD players refuse to honor the force subtitles option and it won't work on those players. It will work on most DVD players though.
This is an expanded version of the above:
subtitles_on_default_pgcedit.
This looks complicated, but in most cases, you just add a single "pre" command and save.
Set Default Player for FLV format?
By schwine in forum Newbie / General discussionsReplies: 5Last Post: 23rd Apr 2010, 13:38 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 10:51 -
Any way to set default DivX bitrate in AutoGK ?
By spidey in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 01:11
Statistics
Newest guides
Latest tool updates
New media comments
