My camera is out of warranty and I got a minor problem with it. The microphones (both of it) does not pick any sound, and the front LED light will not come on. I suspect a cable inside had worked loose or something but I have no idea how to take it apart. I was hoping to get the front panel under the lens off but it seems there's about a baillion screws to work through.
Failing that I have an eye on eBay for non working GS39/59 (both virtually identical) to use for replacement part(s)
Any idea where to find a take apart diagram or advice on fixing the camera? Yes the volume is set up not muted, and yes I double checked the manual to make sure I didn't miss something.
Results 1 to 1 of 1
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15 -
Camcorder not detected on PC-Panasonic PV-GS39
By skumar in forum CapturingReplies: 2Last Post: 14th Sep 2007, 00:37 -
AC adaptor for PANASONIC PV-GS39
By crocker5731 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 2nd Sep 2007, 14:59 -
Panasonic PV GS39 will not power up
By finally17 in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 28th Jul 2007, 00:04
