I have an old sony dvd rec / VHS and all the disks I burn will not play on any of my DVD players. From what I have read on this forum the model I have would make a better boat anchor than a DVD recorder. So I need to purchase a new recorder. I would like one with a DV in port to hook up my camcorder to. Can someone recommend a good recorder? Would a hard drive speed up the process? Is this the best / fastest way to transfer my old tapes?
Thanks in advance for the HELP!!
Try JVC , Pioneer, LG,Toshiba and panny. All will give you good result, some better than others. Hard drive will not speed up process but can but use as good storage. For other inform check old post....
I'm not able to help with recorders. I do transfer hi8 etc. Your question regarding best / fastest is not really answerable as it depends on what you want to achieve.
Is it the best depends on the quality of your original footage and what your expectation is of the result. I spend a lot of time on the PC correcting color and exposure etc. You might be happy with what you get from the footage you have without any editing.
Is it the quickest? Well, probably. But refer to the previous question about is it the best.
Only if you need to edit the captures. Non-hdd recorders capturing to dvd-r or dvd+r in video mode do not provide any means of editing the video other than making a title or changing a thumbnail typically. Editing can happen with rewritable media such as dvd-ram, dvd-rw, or dvd+rw but to burn to dvd-r or dvd+r requires transferring the content to a computer. Rewriteable media is slower than non-rewriteable media so it will take 15-20 minutes to do that transfer.Would a hard drive speed up the process?
The advantage of a hdd model is that you can capture many dvd's worth of material and then edit and burn to dvd video mode disks without having to transfer to a computer. There are some downsides. Hdd models cannot do frame accurate edits and transfer high speed to a disk, typically the menu options are limited ( the Toshiba models may the exception ), and they have very poor availability in the US.
What Sony model do you have which is supposed to be so bad?
I have a Polaroid DRM-2001G and it is excellent for transferring 8mm and VHS sources.. In almost all cases the copies look better than the original thanks to the filtering of the LSI chipset. It also has an 80G hard drive which I found really helpful.
These used to be available at Walmart for just over $200. You may be able to find them on ebay.
I did not use the DVD recorder for editing, so I can't comment on that aspect. I would burn a DVD and then bring it over to my computer for editing and menu creation.
miniDV tapes to DVD
By zoranb in forum MacReplies: 37Last Post: 7th May 2011, 16:32 -
Hi-8 tapes need to transfer to DVD
By jbitakis in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 11th Apr 2011, 03:42 -
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 22:51 -
Hi8 takes MiniDV tapes??
By OM2 in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 26th May 2009, 05:23 -
What I want to do: Transfer/capture old VHS and Hi8 family tapes.
By Boomer1948 in forum CapturingReplies: 7Last Post: 4th Jan 2008, 22:19
