VideoHelp.com Forum
    I inadvertently erased files from my Sony HDR-SR1, then recovered the files with a conevntional recovery program.
    The result: the cameras hard drive is full, but none of the files appears in the index. The file structure is in tact, but the Stream subdirectory is full of *.MTS files preceded by an underscore (i.e. _00.57.MTS) and other MTS files that I don't know how to access.
    Help?
    copy the files off the cam as .mts then you should have the Sony Disk Utility that comes with the cam that will allow you to convert them to mt2s transport streams you can edit. afterward you should probably reformat the cam h.d.
    Thanks. Sorry for the newbie question, but how do you to convert them to mt2s transport streams?
    i don't have that cam but it's supposed to come with a disc utility software that can do it for you.
  1. Sony HDR-SR1 and MTS File Conversion to MPEG
    By cptspoofy in forum Video Conversion
    Last Post: 16th May 2011, 12:24
  2. Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
    By UltimateEnd in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Oct 2009, 11:00
  3. Can you burn directly from Sony hdr- sr1 to blue ray disc, How?
    By pistol pete in forum Authoring (Blu-ray)
    Last Post: 12th Mar 2008, 03:49
  4. Capturing from a Sony HDr SR1 using Intensity pro
    By trydowave in forum Capturing
    Last Post: 22nd Oct 2007, 18:42
  5. Problem installing Sony HDR-SR1 on XP.SP2
    By erik010 in forum DVD & Blu-ray Recorders
    Last Post: 1st Jul 2007, 06:40
