Hi,
Im using ImTOO DVD Ripper Platinum 4 to rip some ac3 2ch files to wav 44.1khz 16bit 1411kbps. In the settings/ preferences/ dvd tab there is a dolby surround option that is checked. the manual says "Dolby Surround: If the box is checked, the better 5.1 FX will be maintained in the stereo". My question is does anyone know if it effects the my file if i am ripping it to a wav and not an ac3 file? I have ripped it both it ways and it sounds and looks identical in sound forge. I was wondering if someone knew forsure.
I have one other question. For the best quality, should i be ripping my wavs with ImTOO DVD Ripper and adjusting the volume through the settings/ preferences/ dvd tab or should i rip them through DVD Audio Extractor with no normalization and adjust the volume through Sound Forge Later?
Thank You Very Much For Your Time And Effort
I Really Appriciate It
X
Results 1 to 1 of 1
dvd audio audio extractor keeps closing
By adept777 in forum AudioReplies: 1Last Post: 3rd Apr 2012, 03:19 -
WinX DVD Ripper Platinum Ripping at Wrong Bitrate
By wperry1 in forum DVD RippingReplies: 3Last Post: 11th Nov 2011, 01:02 -
ImToo DVD Ripper problem
By -phenom- in forum DVD RippingReplies: 2Last Post: 9th Aug 2010, 10:52 -
DVD Audio Extractor can't listen audio preview
By lupio in forum AudioReplies: 8Last Post: 26th Apr 2010, 11:51 -
ImTOO DVD Ripper Platinum Works Well but Would Like Smaller Files...
By w6rlf in forum Video ConversionReplies: 2Last Post: 18th May 2009, 12:30
