VideoHelp.com Forum
    I'm a newbie and am looking for help. I burned a Blu-ray (Sony BD-RE Ver 2.1/2x) off my Dell XPS using Encore CS3. It is not a complex, no menu or chapters just a 4.5 minute demo. It plays great on my computer...but my Sony Blu-ray player does not recognize it. I want to use this demo for an upcoming event using my Blu-ray player and my HD TV. Can anybody advise what I need to do to correct this problem. I'm all ears
    Maybe it doesn't like burned blu-ray media. I would check and ask in http://www.avsforum.com/avs-vb/forumdisplay.php?f=149
  3. Member Krispy Kritter's Avatar
    I don't know all of the new standards...however, the specs for your player list that it supports BD-R/RE with a special note that states "(BD-MV only. Requires firmware higher than ver.1.55)".
    http://www.sonystyle.com/webapp/wcs/...uctId=11040237
    Google is your Friend
    Thank you for the input....I have registered for the avs forum and will seek help there too. I am in a quandry how to trouble shoot this especially since Sony does support the media I'm using
  5. Member Krispy Kritter's Avatar
    Does your player have the correct firmware as noted above? This is a known issue and corrected with updated firmware.
    I've also seen references that the disc must be finalized.
    Thank you for your input. I remembered that Sony mailed a software update which I forgot to install. After installing my disc plays great
  1. Sony BDP-BX37 Blu-ray player and media streaming from a PC
    By HellBell in forum DVD & Blu-ray Players
    Last Post: 4th Dec 2011, 08:39
  2. Replies: 9
    Last Post: 8th May 2011, 02:03
  3. issues playing burned DVD's on sony blu ray player bdp-s300
    By cdcutlip in forum DVD & Blu-ray Players
    Last Post: 7th May 2011, 15:12
  4. Play files without authoring on my blu-ray player Sony BDP-S360
    By vandaLo in forum DVD & Blu-ray Players
    Last Post: 3rd May 2010, 23:50
  5. Problem with sony blu ray player BDp-S500
    By fceurich in forum DVD & Blu-ray Players
    Last Post: 4th Feb 2008, 11:00
