I'm using the JVC MH300, though most other JVC HDD/DVD combi's should have the same functions. The plan is to record to HDD at HQ and dub to disk at various FR after I've topped and tailed the program. Sometimes this could mean editing ads too or with VHS extracting programs from 3hrs of footage. That's why the playlist option is handy as it doesn't cut-up origonal.
Problem - after finalising a disk (all dvds VideoMode) the chapters vanish.
If you record direct to DVD you get 5min autochapters, on the HDD you get 15min autochapters.
I've tried creating my own chapters on the origonal before dubbing using playlist, but they still go. Using a RW disk, if you unfinalise you get the chapter points back? The dubbing is in realtime not high speed.
The other option is to edit using the 'divide' and 'delete scene' functions. This destructive editing method seems to retain chapter points when dubbed.
If I have to I'll use this but play list is better.
Also, am I right in thinking that deleting small sections of a program can cause fragmentation of the HDD.
JVC has no defrag, e.g. Liteon's. That's another advantage to playlist.
Any one found a way round this of am I missing sometime?
Come on someone's got to have a
JVC DR-MH20
DR-MH30
DR-MH50
DR-MH200
if not a DR-MH300, they should be the same and all have playlist editing, even if there are stight differences.
Have you noticed this or solved it?
Cheers
What's up with the thread subject?
Darryl¤ª"˜¨¨¯?¯¨¨˜"ª¤_ No Chapters using Playlist on JVC HDD _¤ª"˜
no one know why I can't get chapters, that's what!
I don't know that defrag is necessarily needed. Defrag is mostly intended for drives with lots of small files. Even a "small" video file is very large.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Good point, as most HDD origonals are in HQ - that must be over 1MB/sec - so there not small files as in - PC text files small etc.
That said a small portion of memory is used for temp. data such as disk library resume, index pics. these could cause some issues. Not a problem now though.
I'm now planing on avoiding playlist for now and being careful to start and stop recording at the correct points. Didn't think I'd need to do this, but there you go. Anything for the love of precious chapters
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
"HDD NG" displayed after HDD replacement on Panasonic DMR-EH60
By Bud5 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 16th Jan 2010, 15:58 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
