I'm recording 16:9 mode on a GL2. How should I handle this stuff in Premiere Pro (project settings, etc.)?
Results 1 to 12 of 12
Thread: Canon GL2 16:9
DV Wide NTSC 720x480i project setting and 16:9 720x480 lower field first MPeg2 encoder settings.Originally Posted by kippard
pwned. Thanks again edDV.
The exported files don't automatically display at 16:9 - suggestions?
In what software ? No all playback software correctly respects the AR settings in the file.Originally Posted by kippard
VLC, Zoom. Should I export an AVI (not DV) with a specific frame size to guarantee the 16:9 aspect? Thanks guns!
DV has an aspect ratio flag which should be set by Premiere Pro and seen by VLC. When you exported as DV, I assume you used the NTSC 16:9 DV template.
Yeah, dunno why VLC plays it 4:3. Should I do a custom AVI?
Open the file in g-spot and see what Premiere wrote to it. g-spot should see it as 16:9 if Premiere did it's job correctly.
I guess the other question is - what are you going to do with the file ? If it is for DVD, then you can just encode it 16:9 anyway, and it won't matter that the avi wasn't flagged correctly.
FAR 1.500 (3:2) in GSpot. You're right, the VOB I made is fine, but I want to make a big nice, big web file too (one that will definitely display at 16:9).
For the web you are better off creating an output with 1:1 PAR, so you should output using a custom template in a suitable codec. 854 x 480 should give you 16:9 with a 1:1 PAR
Help broadcasting from Canon GL2 to Epson Powerlite S5 projector
By flipzoso in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 31st Dec 2009, 15:51 -
Video capturing with a Canon GL2
By dfisher052 in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 30th Aug 2009, 14:24 -
Getting a film look with a Canon GL2
By pbear23 in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 2nd Oct 2008, 18:17 -
Canon GL2, XL1, XL1S, or...?
By nopEda in forum Newbie / General discussionsReplies: 7Last Post: 27th Aug 2008, 15:38 -
Protecting Canon XM2/GL2 Lens
By foxbox in forum Newbie / General discussionsReplies: 0Last Post: 19th May 2008, 08:48
