i hav a PAL system PS3
i am yet to buy a TV
i wanted to go for an LCD monitor and play PS3 via hdmi to dvi converter
but will the PAL thing affect me
how can i play ps3 on a lcd tv ( budget 300$) on good resolution (not cable tv resolution)
Thread: how to play PAL Ntsc PS3 in USA
You probably won't be able to use it to play NTSC DVDs or BluRay discs, or use it on a NTSC only display.
Some LCD TVs but NOT all sold in the USA support PAL resolutions. I have a Samsung LCD TV and it does NOT. You will have to do some research to find out what brands will support PAL. Many if not most LCD TVs sold in the USA will not support PAL at all. At the price range you are looking it, it may be impossible to find a TV that will work.
You could search online for "multistandard TV" and buy something that will work but whatever you find this way won't be in your price range. In Europe, most TVs sold support PAL and NTSC, but in North America, it is almost impossible to find something that will support PAL. Again, a few LCD HDTVs have been reported to support 576i here in the USA, but I don't remember which models.
but what if i connect my Ps3 to a computer monitor??
i can use an HDMI - DVI cable and use it on a computer monitor???
will it work then
You might try here:
http://www.110220volts.com/Merchant2...nasonicTV&Ref=
This is a pretty good price for a ntsc/pal tv to hook up your playstation to.
Originally Posted by yojay16
Yes this SHOULD work.
note I said should not will. should is a very nice world where everything works...... this is the real world....
Convert PAL Signal to NTSC for USA HD Plasma
By hilite in forum DVB / HDTVReplies: 5Last Post: 25th Aug 2011, 06:11 -
Import BluRay, PS3, PAL/NTSC, etc. (Help Plz!)
By Startropic1 in forum Blu-ray RippingReplies: 12Last Post: 22nd Sep 2009, 22:21 -
Camcorder for USA and Europe, NTSC - PAL
By animaeme in forum Camcorders (DV/HDV/AVCHD)Replies: 9Last Post: 17th Mar 2009, 07:29 -
PS3 Pal/Ntsc flavors over HDMI?
By tambur in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2008, 15:57 -
Converting Region 4 (PAL?) dvds to NTSC (USA)???
By denise8593 in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2007, 07:09
