I am about to purchase a Canon HV20 and I want to be able to play the recorded HIGH DEF video on my media player (Mediagate MG350HD)
I also have a Dvico TVIX 5100 media player that plays h264
I wont be using the SD feature of the Canon, and I plan to record in the HDV(PF25) mode on the HV20 (PAL)
I need to know what program I need to purchase to download the HD recorded video to my pc in a .ts or .mpg format, so hopefully I can edit it in VideoRedo and I play it in my media player.
I have a digital tv tuner card that I can record 1920 x 1080 HD (ts) and edit with VideoRedo and output as a .ts or a .mpg and play it on my media player.
Is it going to be this simple with the HV20 ???
The HV20 as with the HV10 record to tape in mpg2 elementry stream. So you can use Pinnacle Studio 10 or 11 or even Liquid to capture it. If your media center can play elementry streams then your set. If not you can pick an export format. Mpg2 muxed, HD DivX, WMV HD etc.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
most HD cams come with software to cap
Author, Producer, Composer, Director - HC5 HDV, FS-1 SLR
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Zoobie; the Canon HV20 does not come with any software to capture VIDEO. Not in my neck of the woods anyhow.
THANKS to everybody else for their replies
You need software and a computer that can "handle" HD............
Not all software will recognize an HD cam...
Read ALL the spec's first...
Playback of MTS files (Canon HF series) using WesternDigitalHD Media Player
By frmsuv2van in forum Camcorders (DV/HDV/AVCHD)Replies: 7Last Post: 22nd Dec 2009, 02:29 -
Canon HV20/HV30
By Tyler2000 in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 31st May 2008, 14:43 -
Canon HV20 Won't turn on
By GasMan08 in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 27th May 2008, 01:51 -
CANON HV20
By onionfish in forum CapturingReplies: 3Last Post: 12th Jan 2008, 17:28 -
Capturing with the Canon HV20
By seven_deuce offsuit in forum Camcorders (DV/HDV/AVCHD)Replies: 33Last Post: 2nd Nov 2007, 23:48
