Recently my LG DVD 4167B writer has started leaving visible rings when trying to write to RW media. Normal media works find, both CD & DVD non-RW media is fine...Is there a different process at work when burning RW vs non-RW media?? Is the drive trashed??![]()
Thanks.
Bill
Thread: DVD destroying RW media
WHO says that drive would "destry" your media??
This is only your impression, and its faulty.
If you have trouble with one media, use another brand/type.*** Now that you have read me, do some other things. ***
Rings as in scratches or just visibly different colors (lighter/darker) of the media on the recordable side of the disc? If they are scratches, it is a hardware problem and would likely be happening with all media. It you are just seeing the "rings" on the media side of the disc, you are only seeing where data has been burned onto the disc. Which is usually unnoticable on a disc that is full, but pretty obvious on discs with smaller amounts of data. You should see similar "rings" on other recordable media, but it is more obvious on DVD-RW media.
Google is your Friend
If the RW's play/are readable in your computer.....they are not damaged and your dive is not "trashed".
Recommended blank DVD media and recommended media storage methods
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video StreamingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
dvd recorder keeps destroying my recordings
By postie1392 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Mar 2009, 07:30 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
Statistics
Newest guides
Latest tool updates
New media comments
