I capture from Sony HC3 using capdvhs. I use my son's PC with Vista Premium and the included MovieMaker. Like I said in my previous post, video quality of the DVD is very good when watched in HDTV. However, I just notice that the audio in some clips are out of sync, while others are just fine - in one DVD project which is 70 minutes long and the source of which is mostly from a single tape. By "clip", I mean the file created when I press STOP during capture. I hope someone has an idea what's causing this to avoid repetition.
Also, when adding music to a particular part of the video, does anyone knows how to mute the audio of that part only without muting the whole video? Every time I use the volume adjustment for the track, the change is global. It would be nice if it only affects a clip. Then I can split and separate that part containing the music.
Another one. When authoring direct from HD-Mpeg2, the menu scene selections are blank whereas, if I convert the video to DV first, the menu shows the animated selections. Problem is, don't know why there is obvious degradation of the resulting DVD. Perhaps the camcorder is not doing a good job converting HD to DV.
Results 1 to 1 of 1
export subtitles created/synched in Authoring Works
By ecc in forum SubtitleReplies: 1Last Post: 21st Feb 2009, 19:44 -
Audio and video get out of sync when authoring MPEG2 to DVD
By palex in forum Video ConversionReplies: 13Last Post: 26th May 2006, 11:11 -
DVD Burns but Audio isn't synched!
By SEViN in forum Authoring (DVD)Replies: 0Last Post: 8th Jan 2004, 16:01 -
Finally I found a way to keep my mpeg2 synched
By easteast in forum EditingReplies: 1Last Post: 16th Aug 2003, 13:38 -
convert mpeg2 to svcd using moviemaker capture
By benbaker in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2001, 21:19
