VideoHelp.com Forum
  1. This has happened to two cameras. You see I'll put a tape in and then review it, and I guess it's a bad tape because I heard some weird noise when fast forwarding and the next thing I know, the time-code is always at 0:00, and the camera detects absolutely NO footage when there is lots of footage. All I get is a blue screen when I hit play
    I thought it was the cameras fault, so I got a new one. And that same tape was playing fine, until I was fast forwarding, heard a strange noise and now this camera has the time code at 0:00, and detects no footage when I play it.
    What the hell is going on here?? Can someone please tell me how to fix it. Furthermore I have VERY IMPORTANT footage on this tape that keeps on screwing up the camera, so how am I suppose to get it off??
  2. Member edDV's Avatar
    Is this DV tape?
    The noise may mean the tape is creased or folded. Start transferring to the hard disk at 1x speed from the start until it stops capturing. Then stop and examine the tape.
    If "VERY IMPORTANT" there are tape recovery experts that can unspool the tape and get it dubbed.
  3. I don't think that's the issue. The tape won't play at all. I have tried many. And all I get is a blue screen when I press play and the time code always stays at 0:00
  4. Member edDV's Avatar
    Only this tape?
    What else would cause noise during shuttle other than a tape mechanical issue? This often happens with VHS but I've never experienced it with 8mm or DV tape.
  5. This has happened to two dv cameras. Ever since that happened. I can't play any tapes. The tapes don't detect any footage, no matter what tape it is. time code is 0.00 all the time. What could be wrong?
  6. Member gadgetguy's Avatar
    Does the tape physically turn when you press play?
    Buy My Books
  1. constant buzz from earphones
    By ecos in forum Newbie / General discussions
    Last Post: 4th Feb 2012, 18:43
  2. Can't get constant power to the motherboard
    By DarrellS in forum Computer
    Last Post: 20th Apr 2010, 21:12
  3. Constant resolution in GK
    By eliqush in forum Editing
    Last Post: 5th Aug 2009, 10:28
  4. I need a constant bitrate
    By alexv305 in forum Newbie / General discussions
    Last Post: 6th May 2008, 06:38
  5. Variable and Constant bitrate ??
    By VEBouto in forum Newbie / General discussions
    Last Post: 17th Oct 2007, 23:56
