Results 1 to 9 of 9
    The only things I've changed today are installing Itunes (to setup my iphone), updating my video card driver, and that's about it.
    For some reason, Media Player Classic won't play my wmv files anymore. I get the failed to render popup.
    Gspot says "codec status undetermined" which is for wmv 1, 2, 3..etc...
    Does anyone have any idea?
    My OS is Windows XP.
    VLC will play it but I find this strange.
    Does it work fine in windows media player? Maybe just try reinstall it.
    It does play fine in VLC and WMP. I did delete MPC and redownload and instlal it but no change.
  4. Renegade gll99's Avatar
    I googled
    MPC WMV
    and it came up with this list:
    http://www.google.com/search?sourcei...D:en&q=mpc+wmv
    The first one in the list looks promising. It says you need wmp 6.4 installed first. They provide a direct link to wmp 6.4 in case yours is damaged or deleted. There is also a link to a codec pack which will only install if you have wmp 6.4 installed. MPC must need DLL's of the older wmp to work.
    http://www.msfn.org/board/Media_Play...MV_t37370.html
    MPC plays wmv ok on my system but I prefer KMPlayer and don't use it much myself. Don't know if the instructions on that site work but they sound reasonable.
  5. Banned
    Is your MPC still configured correctly?
    Thanks everyone for their help so far.
    I did make sure everything is set correctly on MPC.
    Here is a screensot of the screen that appears when I try to play a wmv file.
    Downloading the codecs pack that was linked did improve the situation. When I close the error screen, I can view the wmv now so I'm partly there. I downloaded the runtime 9 for wmp and that didn't help.
  7. Renegade gll99's Avatar
    The screenshot is not showing. If it's a jpg or GIF under 2 mb you can post it directly here
  8. Member waefwaeefwaefw's Avatar
    try changing the MPC output to hail
    Lol, a year later someone responds.
    I don't even remember having this problem.
  1. Media Player Classic can no play DivX files
    By siluet in forum Software Playing
    Last Post: 30th Sep 2008, 16:46
  2. Media Player Classic can't play TS files
    By Mylo in forum Software Playing
    Last Post: 27th Sep 2008, 13:41
  3. Replies: 4
    Last Post: 1st Aug 2008, 23:49
  4. Solved: Can't Play WMV in IE with Media Player Classic.
    By DarrellS in forum Software Playing
    Last Post: 13th May 2008, 12:31
  5. Codec to play WMV HD files in Media Player Classic?
    By madmartian in forum Software Playing
    Last Post: 14th Apr 2007, 13:05
About   Advertise   Forum   RSS Feeds   Statistics   Tools
