I'm looking to buy some new batteries for my camcorder but the cost for manufacturers batteries are pretty high. I'm curious if anyone else has bought 3rd-party or OEM batteries and if they're good. Are there any brands that are good or certain brands to stay away from?
Thanks,
J
Thread: Camcorder batteries
I've actually had pretty good luck - and pricing - over the years from different web vendors. Just always make certain of the guarantee, read the website reviews, and try to purchase a higher specification battery than your camcorder came with.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Well I took the risk and ordered recently thru lajal.com's ebay store. For about AU$50 I picked up TWO 4-hour batteries plus charger for my JVC camcorder. Was delivered in 2 days! I immediately charged the batteries up & tried them out, everything works fine, battery indicator says "240mins". I am very happy - considering just one JVC-brand battery would have set me back $300 or so...
they are the same...you just pay more for "original" made in china....
use ebay, I got a canon oem for 25 and original is about 150.....and it works just fine, and it's like 18 months old already.
That was the main reason I was looking (longer record time). Thanks.Originally Posted by classfour
J
VBN 260 Batteries for Panny TM900 Camcorders
By pepegot1 in forum Latest Video NewsReplies: 2Last Post: 22nd Dec 2011, 18:53 -
Cheap chinese batteries fault or my charger ?!
By JoseD in forum Camcorders (DV/HDV/AVCHD)Replies: 12Last Post: 6th Oct 2008, 17:23
