VideoHelp.com Forum
    Hi,
    I just installed XP from scratch and applied all patches as well as WMP 11 and it's patches.
    Then I installed klite full and chose the default option.
    Now I can play just about all video on Windows Media Player but whenever I try to open any video in MPC I get an error that it cannot render the file.
    I've uninstalled and reinstalled klite several times but the problem persists.
    Is there anyway to fix this?
  2. Member yoda313's Avatar
    try videolan player (vlc). It also has internal codecs. That should be similar to mpc.
    However you probably might be better off reinstalling xp again and NOT INSTALL the codec pack from the beginning. Leave only the codecs you need on it. Or better yet like you tried use only media player classic or vlc to play the files.
    A clean system is a happy system
    I think I will rebuild it, it's messed up already. I think the windows patches are crap and they make some apps crash. I think SP2 is as far as I'll go this time.
    >> Leave only the codecs you need on it.<< what do you mean?
    Cheers
  4. VH Veteran jimmalenko's Avatar
    he means use gspot to identify the codec(s) you need to play each file, and only inst all that/those codec(s) then. Codec packs tend to install a whole heap of crap you will never need and can often cause more problems than they fix.
    If in doubt, Google it.
  5. Member SanderMan's Avatar
    Yep. Klite sucks. Try ffdshow instead.
  1. How to play CUE in Media PLayer Classic
    By lovyagin in forum Audio
    Last Post: 21st Nov 2009, 00:41
  2. Media Player Classic won't load ffdshow - choppy video
    By ioda006 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 6th Jun 2009, 21:44
  3. Media Player Classic won't play WMV files?
    By majax79 in forum Software Playing
    Last Post: 25th Nov 2008, 04:05
  4. Media center video won't play on standalone dvd player
    By larrym in forum Newbie / General discussions
    Last Post: 7th Jun 2008, 22:04
  5. Replies: 0
    Last Post: 4th Jun 2007, 18:19
