hi, i'm in the process of ripping the audio using VOB2audio but after i hit start this message appear " Intervideo audio decoder cannot be found" and its says i need to register the filter. i have no idea how to do that. can you please help me, and post the step by step procedure to solve this problem. thank you very much
randy : :cry:
reinstall Vob2audio as this will install it for you and register it...my i ask question did you have WinDVD install when you installed Vob2audio and you uninstalled WinDVD after the instalation of Vob2audio??? if so that is your problem becuase Vob2audio detects if WinDVD is installed and register WinDVD's Audio decoder to it own
thanks, the WinDVD is a pre-installed software. i think it's part of the package when we bought the computer. i tried to re-install the Vob2audio but the result is the same. i'm getting the same error. how do you think i can resolve this problem. thank you very much. randy
This is from the vob2audio readme (always read the "readme")
"vob2audio is based on directshow-filters, which get registered with the installation of vob2audio.
If you use different versions of the filters and have problems, please use the filters coming with vob2audio, especially don't use the iviaudio.ax version 2.3, use 2.0 instead!!"
Go to c:\windows\system\ and look for iviaudio.ax. Check which version it is. If it is a wrong version install vob2audio once again.
If the filter is still not registered, open the command line console, change to c:\windows\system\ (resp. c:\winnt\system32\) and type
regsvr32 iviaudio.ax
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
YV12 decoder not found in Xvid4PSP, Help.
By saayinla in forum Video ConversionReplies: 10Last Post: 6th Sep 2010, 23:08 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59
Statistics
Newest guides
Latest tool updates
New media comments
