Hi,
I have a .avi file that I would like to convert to a video format so that I can play it on a DVD player. Is there any simple to use, free programs out there that I could use to perform this function.
Thanks,
Aaron
well tmpgenc plus isn't free but comes with a free 30 day trial. It comes with settings to convert to dvd format mpeg2 which you can then import into a dvd authoring program.
http://www.videohelp.com/tools
Check out the list of video encoders above. I believe convertx is recommend frequently here.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Yoy might give DVDFlick a try......good luck!.......
"I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
You can get the free version of Convertxtodvd Here. There is nothing simpler. You just add the file and then click convert and you will have a VIDEO_TS and AUDIO_TS folder you can burn with Imgburn, which is also free.
ConvertX isn't free, but there is a freeware earlier version, DivxToDVD: http://download.videohelp.com/downlo...up_0.52.99.exe
But the payware ConvertXToDVD is well worth the price.
Originally Posted by redwudz
Well, I have here a movie that is MP3 VBR with delays...it gets out of sync
I purchased version 2.2.1.253
I will be very gratefully if you explain me how can I fix this audio
Using VDub to decompress, demux, or recompress it isn't enough ... unless you fix delays and all that stuff
One-click easiest converter ? definitely it is
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 6Last Post: 20th Mar 2012, 10:22 -
why will some avi files play in my dvd player while others will not?
By panman36 in forum Newbie / General discussionsReplies: 6Last Post: 8th Nov 2010, 10:58 -
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
How do I convert various formats TO a dvd that will play on ANY dvd player?
By tinman01 in forum DVD RippingReplies: 11Last Post: 10th May 2009, 12:10 -
AVI wont play on standalone player, need to convert to what
By haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 13:58
