Hi!
I hope i am posting this in the right forum!
I have a vob file of a music video. I convert it to avi using virtualdub. The audio is in sync.
But when i upload it to aegisub and start to add subtitles the audio is out of sync.
Has anyone ever encountered this problem before? (couldnt find anything when i did a search).
Does anyone know what i should to to get the audio in sync (looks like it is aegisub that is the problem, and not virtualdub).
Any help is much appreciated!
Cheers,
denadel
Thread: audio out of sync using aegisub
If you used VBR audio, that can often cause problems. Try CBR.
WAVE is the most trouble free, but it would be huge and probably impractical.
Try creating the project using visualsubsync .
Some programs have problems keeping up in sync .
Thanks for answering my question.
@Bjs: That program doesnt support kanji (japanese letters), so i cant use it..
@AlanHK: I think i will try that to see if it works. But how do i choose to use CBR insted of VBR?
This has never happened to me before. i find it weird that aegisub makes the audio out of sync..
Aegisub effect
By xxxThiefxxx in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 14:35 -
VirtualDub/Aegisub Problem
By FrankXXX in forum SubtitleReplies: 0Last Post: 1st Oct 2010, 11:56 -
What's the best software to sync subtitles to video VisualSubSync,Aegisub??
By LegendaryGamer in forum SubtitleReplies: 1Last Post: 5th Mar 2010, 13:44 -
aegisub
By simonrule in forum SubtitleReplies: 2Last Post: 9th Nov 2009, 04:05 -
Aegisub newbie
By diablo_jones999 in forum SubtitleReplies: 0Last Post: 12th May 2008, 11:10
Statistics
Newest guides
Latest tool updates
New media comments
