VideoHelp.com Forum
Results 1 to 10 of 10
  1. Member the_importer's Avatar
    Not sure if this is the right forum, but anyway.
    So far, all the DVD recorders I've seen have RCA and S-Video Input. Will the quality of my image be degraded to RCA or S-Video when watching TV without recording even if I use the HDMI Out on the DVD Recorder to connect to my TV?
    This is so confusing
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I very much doubt if any would have a HDMI input. That's more for direct connection to displays, similar to your VGA output to a computer monitor.
    I'm not sure what you are asking in the second question. What source are you trying to connect to the recorder and/or TV?
  3. Member the_importer's Avatar
    OK, my cable box is connected to my TV in HDMI, that's how I view my HD channels in 720p. Now in order to record a TV show on a DVD Recorder, I need to place the device between the TV and cable box, so it's:
    Cable BOX====>DVD Recorder ====>TV
    ...............S-Video........................HDMI
    Now by having that S-Video from the cable box to the DVD Recorder, won't I loose the image quality when watching TV even if the DVD Recorder is connected in HDMI to the TV?
  4. Member FulciLives's Avatar
    Yes. You need to hook the cable box up direct to the TV via HDMI or component. If you do it like your illustration then you can only get 480i to the TV ... not 720p or 1080i etc.
    - John "FulciLives" Coleman
  5. Mod Neophyte Super Moderator redwudz's Avatar
    Any time you convert from analog <>digital you will have losses. But box makers and the video companies don't really want you to make one-to-one copies of any of their video. And, depending on their copyright agreements, it's likely not legal anyway. They are not going to make this easy.
    I would continue to view with the HDMI inputs from the cable box.
  6. Member the_importer's Avatar
    If I need to change my setup every time I want to record something, DVD Recorders aren't as useful as VHS were back in the days we didn't have Digital TVs. Guess I'll download episodes someone else recorded instead instead of recording them myself then.
    Thanks anyway
  7. Member edDV's Avatar
    There is no DVD recorder that takes anything but 480i over composite, S-Video or DV 480i. This may change with HD/BD format recorders but they won't allow recording from HD set top boxes, only HD camcorders.
    HDV camcorders may have analog inputs but only for SD to DV format.
  8. Member edDV's Avatar
    Yes, it will be standard def.
    Hook it up this way.
    Cable BOX=(HDMI)=======================>TV
    Cable BOX=(S-Video)==>DVD Recorder ==(HDMI*)==>TV
    *Or S-Video or Analog Component
  9. Member FulciLives's Avatar
    That's exactly what I was trying to say.
    If you find like me that your Cable Box only has a single set of audio outputs then you will either have to use a distribution amp so you can split it into two (one to the TV and one to the DVD recorder) or you can get away without that as I do: Hook the audio out of the Cable Box to the DVD Recorder then the DVD Recorder to your sound source (i.e., stereo). You can record now and when watching the TV just use the DVD Recorder as pass-thru for the audio ... only bad thing is it means your DVD Recorder will be on to pass-thru the audio which means it will be on more often than need be.
    DVD recorders exist to make it simple for you to copy personal VHS tapes to DVD and to record standard definition TV shows to DVD. That is essentially it. There is NO WAY AT ALL with any DVD recorder to record HD video in HD. None. Note that I am not taking about BluRay recorders. I am talking specifically about DVD recorders. Not the same thing.
    If you want to record HD video directly, it is possible to do so via firewire from the cable box to a PC. Encrypted pay channels such as HBO will NOT work with this method. However, if you want to record local HD channels, Discovery and so on, this method will work:
    http://www.avsforum.com/avs-vb/showt...hreadid=403695
    Editing the video and burning it to DVD is up to you though and you should note that almost nothing right now will be capable of playing back these videos. Eventually the players will catch up, but that day is not today.
  1. Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
    By SOHkat in forum DVD & Blu-ray Recorders
    Last Post: 19th Oct 2010, 13:50
  2. DVD Recorder With HDMI Input
    By wulf109 in forum DVD & Blu-ray Recorders
    Last Post: 30th Nov 2008, 14:12
  3. Is there such a thing as a good DVD recorder?
    By ibex333 in forum DVD & Blu-ray Recorders
    Last Post: 25th Oct 2008, 19:00
  4. What is a good DVD Recorder that has Component and/or HDMI Input(s)?
    By KingKRool2002 in forum DVD & Blu-ray Recorders
    Last Post: 26th May 2008, 20:08
  5. DVD Recorder that accepts HDMI or Component input
    By AuditSup in forum DVD & Blu-ray Recorders
    Last Post: 26th Aug 2007, 01:39
