Why is it that everytime I want to edit my video,the output video turns out to be too big and in the end,it says that my hard disk is full.The thing is the original video size is only 20 MB and when edited with vdubmod,the output will be around 3 GB!!Someone help me please,how to make the size as it is or at least not TOO BIG when edited with vdubmod.
Thread: Virtualdubmod problem....
I can't live without my computer.
Most times when editing with VDM, you save out as a 'Direct stream copy'. But that will only work for cuts and pastes, no filtering or cropping. But the file will be the same size, minus whatever you have cut out of it.
If you use 'Full processing mode' and don't select a output codec, it will default to raw AVI and the files will be huge.
So if you are using full processing, be sure to select a codec, usually the same as the input video. You will also have to up the bitrate a little over the original if you don't want too much quality loss. That will make the files somewhat bigger, but not by the amount you are reporting.
Thank u so much.I've tried it and turns out that the size isnt too big anymore but the quality is lost.Can u tell me how to up the bitrate?What to click on?Originally Posted by redwudzI can't live without my computer.
What codec did you select?
If Divx try setting it to "1-pass constant quality" mode and set the "fixed quantizer" to 3.
Xvid's equivalent is called "single pass" and set the "target quantizer" to 3.
Problem with VirtualDubMod - what am I doing wrong?
By bahjan in forum EditingReplies: 2Last Post: 28th Sep 2010, 09:11 -
By darkdream4 in forum Newbie / General discussionsReplies: 8Last Post: 4th Feb 2010, 02:41 -
VirtualDubMod Problem??
By 3thman in forum Video ConversionReplies: 14Last Post: 8th Dec 2009, 11:07 -
By raf.lanna in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:01 -
By Mitchum22 in forum AudioReplies: 0Last Post: 15th Jun 2007, 11:28
Statistics
Newest guides
Latest tool updates
New media comments
