  1. Member mikesbytes's Avatar
    Sydney, Australia
    My near new R230 simply complains of paper jams every time I put paper in it. It's like the paper is too thin for it. I've had a good look and I can't see anything wrong with it. Any suggestions as to what to look for?
    Have a nice Day
    May 2010
    Padangsidimpuan
    Epson R220 and R230 Paper Jam
    SOLUTION :
    This problems could happen because pick up roll rubber was slip or thin.
    Try to clean with dura klin :
    1. Drop dura klin in pick up roll to clean particle/ residue ink.
    2. Drop dura klin in blank paper, and print out several times
    3. Seal pick up roll with cellophane tape so that rubber becomes thicker.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    If the printer is fairly new, shouldn't need drive roller cleaning, but you can check for slick spots on the rubber rollers that usually indicate a need for cleaning. There are different weights (thicknesses) for paper. Usually 24 pound paper is thick enough for most any printer. You might also check for a paper thickness adjustment that some printers have.
