VideoHelp.com Forum
Closed Thread
Results 1 to 27 of 27
    Hi
    I am having a problem similar to some of the ones already described. I have re-installed the program in it's own folder not in Program Files. I have tried using Run as Administrator. As soon as I select any of the DVD burn options the program closes. There does not seem to any log produced.
    Ray
    paparay
  2. Are you running Vista or XP?
    Are you running the latest release of S2D?
    Is an error message produced?
    Do the burn options (programs) you are choosing exist? (Simple question I know, but you'd be surprised...)
    Does the program work otherwise (without burning)?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    I am running Vista Ultimate.
    I am able to add an asset, but soon as I select a burn option the program vanishes.
    There is no error message. The program is just gone. I guess the burn options exist because I am able to select them. This is the latest download.. Thanks for your response. I hope this answered your questions.
    Ray
    paparay
  4. Yeah, I'm a little slow today, Vista was in your subject line
    Have you installed CopytoDVD or ImgBurn? They don't come with S2D. You will need to install one (ImgBurn preferred) to be able to use them.
    Dwight
    - Herm Albright
    I have used this program for at least a year and a half without any problems. I have CopytoDVD installed and that has worked with SVCD2DVD in the past. I just used another program to convert to DVD and CopytoDVD worked with that program. However the main problem is that I never get close to burning as the program closes as soon as I select which mode to process and burn. I have tried MakeDVD and QuickDVDandBurn.
    Ray
    paparay
  6. Are you using the latest release of S2D?
    Dwight
    - Herm Albright
  7. Member ChrissyBoy's Avatar
    No Log? What folder are you looking in?
    Yes it is the latest release.
    Thanks,
    Ray
    paparay
    Sorry there is this in the SVCD2DVD folder
    initial.log
    paparay
  10. Member ChrissyBoy's Avatar
    Try:
    Sorry I did not know how to do this.
    svcd2dvdlog-20070901084537.txt
    paparay
  12. Member ChrissyBoy's Avatar
    That log looks like you burnt a DVD without problem....
    No I did not burn a DVD. I used this for a long time so I would no if I burned a DVD
    paparay
  14. 12:18:15: Finalising DVD...Done
    12:18:15: Done: Authoring DVD Folders
    Burning DVD folder
    13:06:20: Successfully burnt DVD!
    13:06:22: Done: Burning DVD folder
    So can you give us more information on this run? It says it burned, did the burning program fail?
    The log also shows that CopytoDvd is set as the burning option.
    Dwight
    - Herm Albright
  15. Member mr nice's Avatar
    When I converted my avis to dvd then put them onto a disc I have a problem, the root menu buttons don't work it will only play all the files meaning when I try to select one of the tv episodes in the root menu say episode 2 it just stops the starts episode 1. The way I can view the 3 episodes is watch them all in one go. I would much rather be able to pick an episode than after watch them all in one go. Regards macer
  16. Which version of S2D?
    What brand is your player?
    Have you tried the disc any other brand of player or in your PC?
    Dwight
    - Herm Albright
  17. Member mr nice's Avatar
    I have the latest version its the menu that's the problem you cannot select an episode in the menu the buttons don't work.
  18. Stick to the other thread you posted in for this.
    Dwight
    - Herm Albright
    Is this a clean install of Vista or is this an upgrade installation from XP? I also notice from your log that you are doing bittorrent downloads of movies. Shame on you!
  20. I saw that the user was burning TV episodes, not movies. I was under the impression that it was OK to discuss TV episodes here.
    Dwight
    - Herm Albright
  21. Member mr nice's Avatar
    Its a cool program only for the bugs.
  22. Originally Posted by mr nice
    That's really an inappropriate comment based on your limited use of the program. If you can do it better then have at it, otherwise be patient and I guarantee the problem will be addressed.
    Dwight
    - Herm Albright
  23. Member mr nice's Avatar
  24. Member ChrissyBoy's Avatar
    Dwight shut up you must have to much time on your hands.
    No need for that. You have an issue - people are trying to help you. Stick to the thread about menus.
    Be "nice" or you will get NO help.
  25. Member mr nice's Avatar
    Sorry I like the program I just disappointed the menu buttons dont work.
  26. Member ChrissyBoy's Avatar
    Well start by answering the following that were asked of you in the following thead:
    http://forum.videohelp.com/topic337326.html
    1: what make/model is your DVD player?
    2: Can you post your log of the project in question.
    Answer in THAT thread please?
  27. Member mr nice's Avatar
    DVD Player Pacific, Pc DELL. I the disc on both it plays the file in one go but you cannot use the meun buttons. Here is the log. Hope this helps
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.5
    Version: 2.5.3300.0
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
    Executable size: 2.55 MB
    Executable size in bytes: 2682963
    Executable CreationTime: 25/09/2007 19:40:06
    Executable LastWriteTime: 04/10/2007 00:00:44
    Executable LastAccessTime: 04/10/2007 00:05:43
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Home Edition
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 44
    Local: 0809
    Total Physical Memory: 511 MB
    Free Physical Memory: 92.4 MB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.96 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: Gericom
    Computer Model: Ego
    System Type: X86-based PC
    Computer Name: ANTHONY-N7RDEEY
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 1
    User Name: ANTHONY-N7RDEEY\Anthony
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Pentium(R) M processor 1.70GHz
    Description: x86 Family 6 Model 13 Stepping 6
    CPU Speed: 1.7GHz
    CPU FSB: 100MHz
    L2 Cache Size: 0 bytes
    ***************************** Time Zone ****************************
    Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
    ****************************** VIDEO *******************************
    Name: ATI MOBILITY RADEON 9700
    Processor: ATI MOBILITY RADEON 9700 AGP (0x4E50)
    Mode: 1024 x 768 x 4294967296 colors
    Video Ram: 128 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 4.37 GB
    DeviceID: E:
    FileSystem: NTFS
    FreeSpace: 10.2 GB
    ********************* END OF SYSTEM INFORMATION ********************
    01:07:12: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    01:07:12: -->: DVDFolders creating VTS
    01:07:12: -->: VTS 01
    01:07:12:
    DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2.5\dummymenuPAL.mpg...
    01:07:12:
    01:07:12:
    01:07:12:
    01:07:12:
    01:07:12: -->: VTS 02
    01:07:12:
    01:07:12:
    01:07:12:
    01:07:12:
    01:07:12:
    ---------------------------- ENCODING MENU ----------------------------
    TV Standard: PAL
    Aspect Ratio: 4:3
    Image size: 768x576
    Resize size: 720x576
    01:07:14: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    01:07:14: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    01:07:14: libavutil version: 49.1.0
    01:07:14: libavcodec version: 51.27.0
    01:07:14: libavformat version: 51.12.1
    01:07:14: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
    01:07:14: Input #0, image2, from 'C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\background1.jpg':
    01:07:14: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
    01:07:14: Stream #0.0: Video: mjpeg, yuvj420p, 720x576, 25.00 fps(r)
    01:07:14: Output #0, rawvideo, to 'C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\backgroundES.mpv':
    01:07:14: Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=2-31, 1000 kb/s, 25.00 fps(c)
    01:07:14: Stream mapping:
    01:07:14: Stream #0.0 -> #0.0
    01:07:14: Press [q] to stop encoding
    01:07:14: video:73kB audio:0kB global headers:0kB muxing overhead 0.000000%
    01:07:15: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    01:07:15: INFO: [???] File C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\backgroundES.mpv looks like an MPEG Video stream.
    01:07:15: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    01:07:15: INFO: [???] Found 0 audio streams and 1 video streams
    01:07:15: INFO: [???] Selecting dvdauthor DVD output profile
    01:07:15: INFO: [???] Multiplexing video program stream!
    01:07:15: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\backgroundES.mpv)
    01:07:15: INFO: [???] VIDEO STREAM: e0
    01:07:15: INFO: [???] Frame width : 720
    01:07:15: INFO: [???] Frame height : 576
    01:07:15: INFO: [???] Aspect ratio : 4:3 display
    01:07:15: INFO: [???] Picture rate : 25.000 frames/sec
    01:07:15: INFO: [???] Bit rate : 1000000 bits/sec
    01:07:15: INFO: [???] Vbv buffer size : 126976 bytes
    01:07:15: INFO: [???] CSPF : 0
    01:07:15: INFO: [???] SYSTEMS/PROGRAM stream:
    01:07:15: INFO: [???] rough-guess multiplexed stream data rate : 1021744
    01:07:15: INFO: [???] target data-rate specified : 10080000
    01:07:15: INFO: [???] Setting specified specified data rate: 10080000
    01:07:15: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 16473
    01:07:15: INFO: [???] New sequence commences...
    01:07:15: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
    01:07:15: INFO: [???] STREAM e0 completed @ frame 11.
    01:07:15: INFO: [???] Multiplex completion at SCR=3072.
    01:07:15: INFO: [???] Video e0: buf= 40249 frame=000011 sector=00000020
    01:07:15: INFO: [???] VIDEO_STATISTICS: e0
    01:07:15: INFO: [???] Video Stream length: 74883 bytes
    01:07:15: INFO: [???] Sequence headers: 2
    01:07:15: INFO: [???] Sequence ends : 0
    01:07:15: INFO: [???] No. Pictures : 12
    01:07:15: INFO: [???] No. Groups : 2
    01:07:15: INFO: [???] No. I Frames : 2 avg. size 9959 bytes
    01:07:15: INFO: [???] No. P Frames : 11 avg. size 1848 bytes
    01:07:15: INFO: [???] No. B Frames : 0 avg. size 0 bytes
    01:07:15: INFO: [???] Average bit-rate : 1152000 bits/sec
    01:07:15: INFO: [???] Peak bit-rate : 670800 bits/sec
    01:07:15: INFO: [???] BUFFERING stream too short for useful statistics
    01:07:15: INFO: [???] MUX STATUS: no under-runs detected.
    create sub file....done.
    running menu muxer....01:07:17: MUXRATE =4400
    01:07:17: after read_bmp(): xd=720 yd=576 x0=0 y0=0
    01:07:17: Found EOF in .sub file.
    01:07:17: warning, sub on line 0 starts before 4s, (some players won't show it)
    01:07:17: subtitle duration: -1
    01:07:17: ***************** HERE WE GO EVE.ODD *******************
    01:07:17: MenuType: EVEN
    01:07:17: subtitle_packet_size: 973
    01:07:17: subtitle_packet_size & 1: 1
    01:07:17: subtitle_packet_size mod 2: 1
    01:07:17: MenuType==""
    01:07:17: MenuType=="EVEN"
    01:07:17: WAS ODD
    01:07:17: subtitle_packet_size++
    01:07:17: final subtitle_packet_size: 974
    01:07:17: max_sub_size=974
    01:07:17: subtitle inserted at: 0.183033 sd=0
    01:07:17: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
    done.
    01:07:17: SVCD2DVD: DVDfolders
    01:07:17: -->: DVDFolders creating table of contents
    01:07:17: scanning C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\VIDEO_TS/VTS_01_0.IFO
    01:07:17: scanning C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\VIDEO_TS/VTS_02_0.IFO
    01:07:17: -->: Creating menu for TOC
    01:07:17:
    DVD Folders: Processing C:\Documents and Settings\Anthony\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3300.0\menu\menu.mpg...
    01:07:17:
    01:07:17:
  1. virtualdubmod and vista ultimate
    By volam1 in forum Video Conversion
    Last Post: 25th Sep 2009, 10:09
  2. Vista problem with SVC2DVD
    By PerryM in forum SVCD2DVD & VOB2MPG
    Last Post: 27th Aug 2009, 13:34
  3. SVC2DVD quit working on VISTA SP2
    By artar in forum SVCD2DVD & VOB2MPG
    Last Post: 25th Aug 2009, 17:01
  4. SVC2DVD not working on Vista
    By davezim in forum SVCD2DVD & VOB2MPG
    Last Post: 20th Aug 2009, 07:02
  5. Using DVD43 with Vista Ultimate 64?
    By tigertribe in forum Newbie / General discussions
    Last Post: 5th Jun 2008, 14:09
