the duration is misreported at you tube, but if you download the video and check with mediainfo, the duration is correct. That is why it plays normally.
Results 61 to 90 of 1969
Here is a video I just uploaded where you can apreciate the quality a little better. I think I used a bitrate of 800kbps.
http://www.youtube.com/watch?v=vf2MjxPXr8Y
By the way, thanks 45tripp for the fps change command.
I have a new question. Basically does the speed of your internet affect whether a video with 800Kbit would lag? Because I can play a 1000 Kbit video with ease and yet others are saying it freezes aka the netdownload is too much. So I assume then that they need a fast speed to play the vids with no pauses?
yes a 1000kbit bitrate video wouldnt freeze because to freeze it needs to move a litlle firstOriginally Posted by Habboi
here it just loadsssssssssssss
I love it when a plan comes together!
Ricardo Santos
I know,Originally Posted by mgh
it just happens to be immaterial
of course!Originally Posted by Habboi
once the stream has loaded (pause and wait for it), there are no lags
Heh that isn't what I meant sorry. From the feedback I have got even on a full load people have said it freezes at the same point each time. As if their GFX card wasn't good enough or something...Perhaps that is it?
I mean I get the same effect playing a 2 gig 640x480 vid on VLC Player so I assume these people are playing the 1000Kbit on a low end PC...
Am I right?
Thanks to 45tripp I got it working!
http://www.youtube.com/watch?v=8OfQwq3gaLI
http://www.youtube.com/watch?v=wkHtFwExyOI
You are right. Iam from Chile, and many of my friends computers arent very good... mostly somo 4 year P4 with 256mb of RAM and no video card.Originally Posted by Habboi
Connection speed doesnt mean anything once the video is loaded.
Greetings
So then your 600 Kbit vids have lagged for them? Maybe not continuous but at certain points the video just stops...I assume?
the video doesnt play after its loaded, it is streamed, played back as it is loaded.Originally Posted by Revan89
internet connection does matter!I love it when a plan comes together!
Ricardo Santos
Alright someone professional here tell me straight. What defines whether a video will pause for some and not for others? The higher the Bitrate...The more it happens so is it internet speed or the power of your PC?
It's strange because I keep saying I can play a 1000 Kbit fine with no lag or pauses. But then others complain...This seems to happen outside of where I live as all my friends (UK) say it plays fine...Does that have any relevance?
the internet speed no doubt, no need to get "professional help"., i lived in the uk for 7 years and the adsl penetration in the country is very high, you got all those cable companies, the country cable structure was very well planned mate.Originally Posted by Habboi
example:
http://www.cable.co.uk/compare/regio...&x=0&y=0&=Find
take a look at the speeds and the companies, not every country got that
if people have a very slow pc chance is it wont be able to handle a fast net connection to begin with....I love it when a plan comes together!
Ricardo Santos
Thank you that was very clear and precise. I think I have everything I need to know now. Until next time.
Guiboche had problems due to using the uploader mentioned in the thread.
I've edited the guide to reflect this.
Youtube has been updated, and with the update, the resolutions have increased too. Now the encoding should use de 480x360 resolution.
can you provide a link?
i still see 320x240 as official:
http://www.google.com/support/youtub...n&answer=55745I love it when a plan comes together!
Ricardo Santos
As you can see by the new design layaout of youtube, the beta has gone official. Besides that, Some videos I uploaded 5 days ago, with the 448x336 resolution matched perfectly to the player's screen, now they have a black space when I press the "original resolution" button. Check it if you want to: http://youtube.com/watch?v=vf2MjxPXr8YOriginally Posted by trevmar
The embedded resolution its the same, by the way.
I have just uploaded a video with the 480x360 resolution.... just watch as it fits perfectly to the screen:
http://www.youtube.com/watch?v=xwgVADWeNkw
Yo Revan89,
I just downloaded your youtube video - www.youtube.com/watch?v=xwgVADWeNkw
How the heck did you get a bitrate of 760+?
Did you do any "hex" edits or is this the new youtube that accepts 480x360?
Also, I noted that online youtube indicates a duration of 10 minutes when the actual duration is 4:19 at 24 fps!
Also, just wondering if you know how to get h264 (x264) video and/or aac (mp4) audio into a flv container - I tried ffmpeg and it indicated that the flv codec did not accept aac (mp4) audio
TIA
Anybody know why YouTube is re-encoding my video?
http://www.sendspace.com/file/azpmff
That's the source file I'm using. There was no reason to hex edit anything since FPS were under 30 and the A/V bit rate was under 350 kb/s. YouTube is re-encoding it (it doesn't look too much worse than my master) and shitting on the audio (the re-sampling of my already 22 KHz sampled audio sounds god awful combined with the mono sound).
thx.flv
How did you uploaded the video to youtube??Originally Posted by Biggiesized
If you used a third party program, thats yours problem. You have to upload videos thru the site for this system to work.
look to your audio. probably the wrong side of standard.Originally Posted by Biggiesized
I changed audio (upped bitrate, consequentially hexed)
http://www.youtube.com/watch?v=cgXraovJsjQ
read the guideOriginally Posted by wiseant
Of course he did.Originally Posted by wiseant
what's changed to 480x360 is the display size
you don'tOriginally Posted by wiseant
http://labs.adobe.com/wiki/index.php...9:Update:H.264
gl
What do you mean I have the wrong side of standard?Originally Posted by 45tripp
I've been using LAME encoded MP3 stereo audio @ 22 KHz and ~48 kb/s ABR for all of my videos. I've never had a problem with any of them. I see you fixed this, but my question is why would you need to hex edit it at all? You can check out any of my other well encoded videos (I have some that are several months old--they weren't encoded in mencoder so ignore them) and you'll see they use the same specs and uploaded without an issue.
Okay I tried to remaster it with CBR audio @ 48 kb/s instead of ABR (because then it might not hit 48 kb/s on average--mine was actually around 44 kb/s).
It still didn't work when I uploaded it to YouTube. It's like something has changed with them. I've never had to hex a video that met all of YouTube's hidden requirements in the past. Why do you suppose this is happening?
I also fixed the AR ratio of the video. I had it mis-set at 2:1 when it should have been 2.35:1 (an error in anamorphic encoding on my part).
thx_widescreen.flv
Encoding the video with Mencoder. I have "mencoder.exe" in my "C:" drive. Then I put the video I want to convert in my C: drive and I applied this code in Command Line (Start->All Programs->Accesories->Command Line) with subtle changes, depending on the video. (You have to put the name of your video in the code line)Originally Posted by wiseant
Where its says "vbitrate", the number next to it is where you can asign the bitrate of your videos.Code:"C:\mencoder.exe" "C:\myvideo.avi" -o "c:\converted_video.flv" -af resample=44100:0:0 -sws 9 -vf scale=480:-3,expand=480:360 -of lavf -ovc lavc -lavcopts vcodec=flv:vbitrate=600:trell:v4mv:mv0:mbd=2:cbp:aic:cmp=3:subcmp=3 -oac mp3lame -lameopts abr:br=64:mode=3
The only hex edits that I used were to change the video's duration. The 480x360 resolution can be achieved just by evading youtube's encoder. As simple as that. So, use the Hex Edit trick to change the duration of the video, as it is explained in this tutorial, and create an .flv file with an apparent bitrate of 350kbps or less.Originally Posted by wiseant
Thats all.
no you can't check any of your videos.Originally Posted by Biggiesized
my luck being what it is, I had to go through 3 to finally get one like you describe.
next time link specifically.
my estimation is it's non standard.
i'm no expert. take it for what it is.
I have pinpointed audio as the problem though.
should be enough.
the files you mention aren't the same.
if only for the reason that they pass and the 'thx' fails.
you've not provided any info, so i could barely guess, and i'm not in the mood to test in any case.
it could be different serttings, it could be the source, it could be a specific encoder vs another,
it could be a specific version of a single encoder vs another version....
you'll have to test it out.
well obviously it's not meeting requirements.Originally Posted by Biggiesized
I have no idea at this moment why.
because like I said, i increased the audio bitrate.Originally Posted by Biggiesized
specifically i used ffmpeg to pass the video untouched, and re-encode the audio to 64k leaving it
stereo and at 22050.
the higher total bitrate meant i had to hex.
gl
lol i just had to register to post this
i hex edited the 480x360 flv and changed duration from 25 minutes to 10 minutes! uploaded original, youtube rejected it. uploaded hexed flv, youtube didnt bother with it and the video went live!
i know that the original flv's bitrate has to be much lower than the 340Kbps limit, but thats not a problem for me since i typically upload music tracks with static background pic as a vid (1FPS)...
DEMO LINK:
http://youtube.com/watch?v=ZTvtF5njjWQ
I never doubted it,
but it was untested.
thanks for testing.
btw 10:32?
i wonder if that means you can go to 10:59...
I didn't put the 10 min limitation to the test either.
i believe by saying "10 minute limit" they meant "everything below 11", aka 10:59 and below etc...
btw, i tried downloading the youtube video and download speed is around 135KBps to 160KBps. at some times it glitched down to 100KBps but not below it, so if using 100KBps as the lowest common denominator can we conclude that its safe to upload 800Kbps video and have it NOT glitch when watching?
oh and also a question. could you fake both the flv duration AND bitrate?
I'm not sure what happened with my last few video attempts, but my latest works just fine.
Check it out:
http://youtube.com/watch?v=xYxc7QUpx00
You might find it familiar... :P
Recommended upload video format for maximum sound quality on youtube
By waigy in forum Video StreamingReplies: 25Last Post: 12th Sep 2010, 17:09 -
Youtube - bad upload quality
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jul 2010, 02:49 -
Poor quality following upload to YouTube-can anyone assist?
By acceleratorhams in forum Video StreamingReplies: 1Last Post: 1st Jun 2009, 15:16 -
Poor Youtube Quality Upon Upload
By JohnSmith1981 in forum Video StreamingReplies: 1Last Post: 20th Feb 2009, 12:54 -
Youtube HQ upload slow on normal quality
By seiun in forum Video StreamingReplies: 2Last Post: 21st Sep 2008, 13:18
