I used VOB2MPG 2.5 one time and it worked great. Now 1 month later the program will not divide my VOB file into chapters when it converts. I even went back to the original VOB file that converted into 40 individual little videos in August, but this time the output is now just the same size movie file as it was VOB.
Thread: VOB2MPG not creating chapters
From the VOB2MPG tool page:
AFAIK, it never created separate chapter MPEGs, just separate title MPEGs. Are you thinking of a different program?VOB2MPG goes through a whole DVD VIDEO_TS folder and joins up the various vobsets to produce mpgs for the different titles.
And welcome to our forums.
I ran a large VOB through the 1st time and I got each scene in its own separate file/Chapter. This time it came out as one huge movie file that I am trying to separate in Movie Maker and its too much work. The point of videoing to mini DVD is that you have nice chapters of each thing you videod.
VOB2MPG will split titles, and some amateur creations mistake titles for chapters and so author this way. I suspect that footage shot on DVD cameras is also authored this way, with each filming session being recorded as a new title. VOB2MPG doesn't know what a chapter is, only titles.
My point is that VOB2MPG is not functioning the way it did the 1st time I used it and there are no setting within the software to change. so what can I do to get it to spit out individual titles like it did last time?
Is this the same disc as last time ?
What I tried to explain to you (but obviously failed) is that the first disc you did contained multiple titles, which you mistook for chapters. VOB2MPG will split separate titles out to different files. The disc you are now trying to extract has a single title with multiple chapters. VOB2MPG can only extract a single title from this disc because that is all there is.
If you want to con firm this theory, open the disc in DVD Shrink and see how many titles there are.
VOB2MPG only extracts titles, not chapters.
DVDStyler Not Creating Chapters?
By analytalica in forum Authoring (DVD)Replies: 1Last Post: 31st Mar 2012, 18:10 -
VOB2MPG Pro - Playing chapters
By 7andy in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 6th Jan 2012, 12:44 -
Creating chapters (MKV)
By ignorantbliss in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 10:32 -
resetting time codes on chapters using vob2mpg pro
By sbruck in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Oct 2009, 15:53 -
Creating chapters using CCE
By hipatuga1 in forum Authoring (DVD)Replies: 3Last Post: 5th May 2007, 04:10
