Hi All,
I just got back from my local Staples store (Canada) and they have 3 systems I am interested in - does anyone have an opinion on which one is better?
1. Acer Aspire Desktop
Intel Pentium D Processor 925
1 GB DDR SD RAM
200 GB Hard Drive
DVD+/_-RW dual-layer drive
Intel Graphics Media Accelerator 3000
price: $397.00
2. Pavilion Desktop
AMD Athlon 64 X2 Dual-Core Processor 4200+
1 GB DDR SD RAM
320 GB Hard Drive
Super Multi DVD +/-RW RW with LightScribe
NVIDIA GeForce 6150 LE graphics
price $447.00
3. Affinity Desktop PC
AMD Athlon 64 X2 Processor 4200+
1 GB DDR-2 SD RAM
250 GB SATA hard drive
Super Multi DVD burner
ATI RADEON x1200 graphics
AMD/ATI 690V chipset
price: 397.00
These are the only one I am interested in - I am not interested in anything else right now
Any (expert) opinions are welcome
TIA,
wiseant
Results 1 to 13 of 13
Thread: Advice on new Computer Purchase
Personally I would go for number 3. The Pentium D is the cut down, single core version so I would avoid that and all your getting for your extra $50 with number 2 is a bigger hard drive. You could use that extra and put a second drive in number 3. I am slightly biased in that I prefer AMD processors and ATI graphics, so that would swing it for me.
The specs are pretty similar, and some people don't like ATI graphics, I don't like Nvidia. If the price is important, you have a choice between 1 and 3, and there's no contest really. Just make sure you install Windows XP and not Vista to get the best out of whichever you choose.
Thanks Richard G - I appreciate your input.
I am familar with Acer and HP - but not Affinity - think I'll go do some searches
None of the above
By the way the Pentium D 925 is DUAL Core, so it may influence your opinion of the previous poster.
I can confirm that - my main desktop is a Pentium D920 - the 2.8GHz version. I got the system about a year ago from Gateway. Never had a problem with it and I do abuse it (for software development). I actually got a refurbished one and saved quite a bit.Originally Posted by oldandinthe way
You may want to consider contacting the manufacturers to see what they have. I simply searched on the Gateway site for 'refurbished'.
The nice thing about the processors in the 3 you list is that they are considered passé and slow and clunky. Well, I personally don't think so. I'm very happy with the speed of my system. You end up paying quite a bit less since the manufacturers are trying to get rid of them because they're not cool anymore.
Don't forget about the choice of OS, too.
If you are open to other machines consider eMachines/Gateway units before they are acquired by Acer. Particularly their Intel processor machines (which usually have Intel built motherboards).
I have concern about Acer support.
HP has Intel based units in the same price range and I would prefer Intel.
Affinity is an assembler I know little about. Before I bought an Affinity unit, I'd consider building my own.
You might search for a deal on a Lenovo unit. There are some to be had here in the states at Staples as well as other big box retailers. Here in the states Lenovo has great support IBM. Call with a question and you get someone who doesn't treat you like an idiot and insist you follow a script, but is actually capable of listening to your question, what you have tried and finding an answer.
I'd go with the HP system but I don't know if you're able to get XP instead of VISTA. Most bundled pc's come with VISTA & not with XP. For the price of the HP system the AMD dual core processor is fine. I've seen some bundled systems only using a Intel Core 2 Duo Allendale E2160 processors but they're overpriced compared to AMD Dual core systems. Just my 2 cents!
Thanks for the feedback:
I did go and get the Affinity - the box says the parts are asembled in the US - two weeks earlier I bought the Acer Aspire AST180 512 MB RAM 160GB HD SATA-SCSI(!) for $299 - thought that was a decent deal - decent speakers, keyboard, mouse, DVDRW - didn't really like VISTA w/512MB - prefer XP anyway - ran well - returned it - then I saw 3 new choices - just set it up the Affinity (2yr ltd warranty) tonite - setup Services to get rid of all that then foobar8.3 and MPlayer and the built-in software has nice audio management - so I'm thinking $399 seems pretty OK?
I Want to run ffdshow, Avisynth, AvsP, ffmeg, WinFF, VDubMPEG, GUIMencoder - DVDAuthorGUI, Muxman, (maybe CCE, MainConcept, HCenc), and EAC, Audiograbber, Aften, MPlayerC, flac, faac, faad, maybe lame . . .
Now, will dual-core help these apps?
Don't suppose anyone knows which of those apps can utilize dual-core and/or 64-bit?
Any suggestions would be appreciated.
P.S.
oldandinthe way - I was in a hurry and just had to get a new box today - but yes Intel, HP, eMachines are household names - I don't know much about Acer but then seem OK to me - and I have heard of Lenovo before - do they also make external HD?
JohnnyMalaria
"You end up paying quite a bit less since the manufacturers are trying to get rid of them because they're not cool anymore."
yo, kinda looks that way
There's nothing to recommend here - the Pentium D is old and runs hot, and the AMD X2s are outgunned by similar priced Core2Duos.
Regards,
Rob
If you want info on dual cores, its been done here ..
http://forum.videohelp.com/topic3361...ht=dual%20core
What are you going to do with it? Quad cores should be here just about any day now.
Originally Posted by handyguy
Sell it on Ebay
Advice on TV-card purchase.
By Homercleese in forum DVB / HDTVReplies: 3Last Post: 27th Dec 2009, 16:27 -
Where do you go to purchase your online computer parts?
By freebird73717 in forum ComputerReplies: 20Last Post: 4th Dec 2008, 00:46 -
Advice needed in a VHS/DVD recorder purchase
By higgins327 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 14th Aug 2008, 15:44 -
looking to purchase a digital media receiver... need advice.
By odiexx in forum Media Center PC / MediaCentersReplies: 1Last Post: 15th Jun 2007, 13:53
