VideoHelp.com Forum
Results 1 to 15 of 15
    Anyone know of an avi splitter that will allow me to manually split multiple parts of one avi and automatically combine those split parts, allowing me to rename that new creation of course? All of the videos I split will be avi's.
    Hopefully, I explained myself correctly.
    Here are a few avi splitters I haven't had the time to look at but I'm unaware of any other programs:
    speed video splitter
    allok video splitter
    ultra video splitter
    okoker video splitter
    A splitter that I did try and didn't like at all was easy video splitter. For some reason the program would put me back to the first cutting point when I tried to search for the last cutting point.
    The problem with most avi splitters is that joining the files causes audio sync issues. If the parts do not need to be playable as separate parts, use a file splitter like HJSplit instead.
    Otherwise you could try avidemux or virtualdub as well.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    I don't need them to be playable as separate parts so I'll give HJSplit a try.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    I use VirtualDub or VDMod for that. Just cut out the parts you don't want, save what's left over with 'Direct stream copy'. That's just about automatic. If you cut by using the key frames, you shouldn't have any sync problems.
    Wow, very cool.
    I've downloaded VirtualDub and found where I need to change to "direct stream copy".
    Quick question, is there a way to set the program to open with "direct stream copy" selected, or do I need to manually change the video preference each time I use the program?
    Thank you for the recommendation.
  6. Banned
    File > save current settings as default ?
    (or somewhere there, Im on pocketpc atm cant tell you exactly)
    In VDubMod, go to "Options" -> "Preferences...". Right near the top is the setting for "Video Mode" where you can set the default.
    Since VDubMod is based on VirtualDub, the setting should be in a similar location. Hopefully
    Jim
    Hm, neither of the two options seem to work in VD.
  9. Member t0nee1's Avatar
    Is it that big a deal to set it manually? just wondering.....
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
    Why are you interested in this post, lol? Do you have a comment that is applicable to answering my question? I'm not trying to be rude.
  11. Member t0nee1's Avatar
    No I'm just wondering is all,maybe what you need is a 1-click wonder proggy..
    JM2cents,and not trying to be rude!!!
    Um, ok but the question was can I set VD up to open and have direct stream copy auto set.
    So, I don't see how your 2 post fit in?
  13. Member t0nee1's Avatar
    1-click easy ,two click maybe not so easy,I guess..but never mind!!!
    Ok,
    I'll figure it out myself.
    Thanks to the people who helped me. It's greatly appreciated.
  1. Replies: 5
    Last Post: 8th Aug 2011, 18:59
  2. Splitting freeware software
    By Zeev_Zwaard in forum Editing
    Last Post: 23rd Feb 2010, 15:01
  3. Cutting/Splitting AVI Video Files Software
    By Teac23 in forum Editing
    Last Post: 29th Oct 2009, 06:23
  4. Advice required - Formats, splitting, software, outputs
    By glinscott in forum Newbie / General discussions
    Last Post: 19th Sep 2008, 07:00
  5. splitting/rejoining software
    By motleycool in forum Editing
    Last Post: 14th Dec 2007, 17:49
